顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
ABAQUS问题? 120
浏览: 4994 回答: 4
我用的是UMAT子程序,出现以下问题:
The executable standard.exe aborted with system error code 1073740940. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
这是dat文档中的内容:
   Abaqus 6.14-1                                  Date 19-一月-2018   Time 10:56:46
   For use by Supplied By SSQ under license from Dassault Systemes or its subsidiary.
                         The Abaqus Software is a product of:
                           Dassault Systemes Simulia Corp.
                                 Rising Sun Mills
                                 166 Valley Street
                           Providence, RI 02909-2499, USA
                   The Abaqus Software is available only under license
                   from Dassault Systemes or its subsidiary and may be
                   used or reproduced only in accordance with the terms
                   of such license.
                          On machine Shisy
                          you are authorized to run
                          Abaqus/Standard until 31-Dec-2055
                          Your site id is:
                    For assistance or any other information you may
                    obtain contact information for your local office
                    from the world wide web at:
                      http://www.3ds.com/products/simulia/locations/
                *                   *  N O T I C E  *                     *
                *                    Abaqus 6.14-1                        *
                *          BUILD ID: 2014_06_05-06.11.02 134264           *
                *  Please make sure you are using release 6.14 manuals    *
                *  plus the notes accompanying this release.              *
     PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
     END PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
     OPTIONS BEING PROCESSED
  *Heading
  *Node
  *Element, type=C3D8R
  *Nset, nset=ASSEMBLY_PART-1-1_SET-1
  *Nset, nset=ASSEMBLY_PART-1-1_SET-3
  *Elset, elset=ASSEMBLY_PART-1-1_SET-1
  *Elset, elset=ASSEMBLY_PART-1-1_SET-3
  *Node
  *Nset, nset=ASSEMBLY_M_SET-1
  *Nset, nset=ASSEMBLY_SET-2
  *Nset, nset=ASSEMBLY_SET-3
  *Elset, elset=ASSEMBLY_SET-2
  *Elset, elset=ASSEMBLY__S_SURF-1_S3
  *surface, type=ELEMENT, name=ASSEMBLY_S_SURF-1
  *coupling, constraintname=ASSEMBLY_CONSTRAINT-1, refnode=ASSEMBLY_M_SET-1, surface=ASSEMBLY_S_SURF-1
  *kinematic
 ***WARNING: WHENEVER A TRANSLATION (ROTATION) DOF AT A NODE IS CONSTRAINED BY
             A KINEMATIC COUPLING DEFINITION THE TRANSLATION (ROTATION) DOFS
             FOR THAT NODE CANNOT BE INCLUDED IN ANY OTHER CONSTRAINT INCLUDING
             MPCS, RIGID BODIES, ETC.
  *material, name=ZICHENGXU
  *depvar
  *usermaterial, constants=88
  *material, name=ZIDAI
  *density
  *elastic
  *concretedamagedplasticity
  *concretecompressionhardening
  *concretetensionstiffening
  *solidsection, elset=ASSEMBLY_PART-1-1_SET-3, controls=EC-1, material=ZICHENGXU
  *sectioncontrols, name=EC-1, hourglass=ENHANCED
 ***WARNING: THE PARAMETER HOURGLASS = ENHANCED ON THE SECTION CONTROLS OPTION
             IS RELEVANT FOR THESE ELEMENTS: C3D8R, CAX4R, CGAX4R, CPEG4R,
             CPE4R, CPS4R, M3D4R, S4R, SC8R AND THEIR HYBRID, THERMAL AND
             PRESSURE COUNTERPARTS WHEREVER APPLICABLE. IT IS ALSO RELEVANT FOR
             ALL TYPES OF MODIFIED TRIANGULAR AND TETRAHEDRAL ELEMENTS. THIS
             WARNING CAN BE IGNORED IF THE FEATURE IS APPLIED TO THESE ELEMENT
             TYPES ONLY.
  *boundary
  *boundary
  *output, field, variable=PRESELECT
  *output, history, variable=PRESELECT
 ***WARNING: MPCS (EXTERNAL or INTERNAL, including those generated from rigid
             body definitions), KINEMATIC COUPLINGS, AND/OR EQUATIONS WILL
             ACTIVATE ADDITIONAL DEGREES OF FREEDOM
  *amplitude, name=AMP-1
  *Step, name=Step-1, nlgeom=NO, inc=10000
  *static
  *boundary
  *boundary
  *endstep
  *static
  *boundary
  *boundary
  *endstep
                            P R O B L E M   S I Z E
          NUMBER OF ELEMENTS IS                                    90
          NUMBER OF NODES IS                                      177
          NUMBER OF NODES DEFINED BY THE USER                     177
          TOTAL NUMBER OF VARIABLES IN THE MODEL                  582
          (DEGREES OF FREEDOM PLUS MAX NO. OF ANY LAGRANGE MULTIPLIER
           VARIABLES. INCLUDE *PRINT,SOLVE=YES TO GET THE ACTUAL NUMBER.)
                              END OF USER INPUT PROCESSING
     JOB TIME SUMMARY
       USER TIME (SEC)      =  0.40000
       SYSTEM TIME (SEC)    =  0.20000
       TOTAL CPU TIME (SEC) =  0.60000
       WALLCLOCK TIME (SEC) =          5
   Abaqus 6.14-1                                  Date 19-一月-2018   Time 10:56:56
        STEP    1  INCREMENT    1
        TIME COMPLETED IN THIS STEP   0.00
                        S T E P       1     S T A T I C   A N A L Y S I S
     AUTOMATIC TIME CONTROL WITH -
          A SUGGESTED INITIAL TIME INCREMENT OF                2.000E-02
          AND A TOTAL TIME PERIOD OF                           1.000E+03
          THE MINIMUM TIME INCREMENT ALLOWED IS                1.000E-05
          THE MAXIMUM TIME INCREMENT ALLOWED IS                 1.00
     LINEAR EQUATION SOLVER TYPE         DIRECT SPARSE
          UNSYMMETRIC MATRIX STORAGE AND SOLUTION WILL BE USED
msg文档和log文档见附件!
ABAQUS 结构CAE 土木工程 材料工程
全部回答 (3)
B.x 2023年3月17日
解决了吗
2023年3月17日
必亘心 2019年5月4日
如果UMAT中有write语句,也有可能是某条write语句引起的问题
2019年5月4日
影子_1236 2018年3月7日
depvar中没有定义状态变量的个数
2018年3月7日
相似问题
查看全部
  • abaqusDSA设计敏感性分析修改inp Solver Input File Processor? 5个回答
    请教各位大佬,用dsa设计敏感度分析功能做悬臂梁敏感度分析,inp文件用记事本修改后提交,数据检查能过,但是然后立即出现solver input file processor exited with an error,修改了几次还是有问题。请教一下如何解决,谢谢! 悬臂梁inp文件如下百度网盘: 链接:https://pan.baidu.com/s/12kigjtldkkdfog9bpqbtgg
  • inp文件引入接触出错,请问是什么原因? 4个回答
    错误信息: *CONTACT PROPERTY ASSIGNMENT CAN ONLY REFERENCE SURFACE INTERACTIONS WHICH ARE DEFINED AS MODEL DATA. SEE THE SURFACE INTERACTION NAMED INTPROP-1. inp文件: *Heading ** Job name: Job-1 Model name:
  • 用inp文件定义局部坐标各向异性报错怎么解决? 暂无回答
    我定义了一个8单元结构,在inp文件里想通过节点建立局部坐标系来赋予各向异性材料方向,但是导入之后会有“ValueError: operands could not be broadcast together with shapes (0,) (3,) This occurred while creating part level orientation ORI-1. The region in
推荐阅读
ansys结构动力学仿真
ansys结构动力学仿真
技术邻小李 技术邻小李
¥150
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
abaqus埋地管道受力分析
abaqus埋地管道受力分析
冷月 冷月
¥25
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
如何为您的应用选择合适的传声器
如何为您的应用选择合适的传声器
HBK声学与振动 HBK声学与振动
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
Altair FlowSimulator一维流体仿真分析软件介绍&模型搭建案例分享
ALTAIR ALTAIR
免费
