顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
abaqusDSA设计敏感性分析修改inp Solver Input File Processor? 15
浏览: 2637 回答: 4
请教各位大佬,用dsa设计敏感度分析功能做悬臂梁敏感度分析,inp文件用记事本修改后提交,数据检查能过,但是然后立即出现solver input file processor exited with an error,修改了几次还是有问题。请教一下如何解决,谢谢!
悬臂梁inp文件如下百度网盘:
链接:https://pan.baidu.com/s/12kigjtldkkdfog9bpqbtgg
提取码:bd6r
inp文件简要概括如下:
*Heading
** Job name: Job-1 Model name: Model-1
** Generated by: Abaqus/CAE 2020
*Preprint, echo=NO, model=NO, history=NO, contact=NO
*PARAMETER
Pi=-10000
*DESIGN PARAMETER
Pi
** PARTS
*Part, name=Part-1
*Node
'此处省略一万多个悬臂梁网格节点坐标数据'
*Element, type=C3D8R
'此处省略几万多个悬臂梁网格数据'
*Nset, nset=Set-1, generate
     1,  12221,      1
*Elset, elset=Set-1, generate
     1,  10000,      1
** Section: Section-1
*Solid Section, elset=Set-1, material=Material-1
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
*End Instance
*Node
      1, 0.0500000007, 0.0500000007,           1.
*Nset, nset=Set-1, instance=Part-1-1
  1101,  1102,  1103,  1104,  1105,  1106,  1107,  1108,  1109,  1110,  1111,  2212,  2213,  2214,  2215,  2216
  2217,  2218,  2219,  2220,  2221,  2222,  3323,  3324,  3325,  3326,  3327,  3328,  3329,  3330,  3331,  3332
  3333,  4434,  4435,  4436,  4437,  4438,  4439,  4440,  4441,  4442,  4443,  4444,  5545,  5546,  5547,  5548
  5549,  5550,  5551,  5552,  5553,  5554,  5555,  6656,  6657,  6658,  6659,  6660,  6661,  6662,  6663,  6664
  6665,  6666,  7767,  7768,  7769,  7770,  7771,  7772,  7773,  7774,  7775,  7776,  7777,  8878,  8879,  8880
  8881,  8882,  8883,  8884,  8885,  8886,  8887,  8888,  9989,  9990,  9991,  9992,  9993,  9994,  9995,  9996
  9997,  9998,  9999, 11100, 11101, 11102, 11103, 11104, 11105, 11106, 11107, 11108, 11109, 11110, 12211, 12212
 12213, 12214, 12215, 12216, 12217, 12218, 12219, 12220, 12221
*Elset, elset=Set-1, instance=Part-1-1
   991,   992,   993,   994,   995,   996,   997,   998,   999,  1000,  1991,  1992,  1993,  1994,  1995,  1996
  1997,  1998,  1999,  2000,  2991,  2992,  2993,  2994,  2995,  2996,  2997,  2998,  2999,  3000,  3991,  3992
  3993,  3994,  3995,  3996,  3997,  3998,  3999,  4000,  4991,  4992,  4993,  4994,  4995,  4996,  4997,  4998
  4999,  5000,  5991,  5992,  5993,  5994,  5995,  5996,  5997,  5998,  5999,  6000,  6991,  6992,  6993,  6994
  6995,  6996,  6997,  6998,  6999,  7000,  7991,  7992,  7993,  7994,  7995,  7996,  7997,  7998,  7999,  8000
  8991,  8992,  8993,  8994,  8995,  8996,  8997,  8998,  8999,  9000,  9991,  9992,  9993,  9994,  9995,  9996
  9997,  9998,  9999, 10000
*Nset, nset=p
 1,
*Elset, elset=_s_Surf-1_S3, internal, instance=Part-1-1
    1,    2,    3,    4,    5,    6,    7,    8,    9,   10, 1001, 1002, 1003, 1004, 1005, 1006
 1007, 1008, 1009, 1010, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 3001, 3002
 3003, 3004, 3005, 3006, 3007, 3008, 3009, 3010, 4001, 4002, 4003, 4004, 4005, 4006, 4007, 4008
 4009, 4010, 5001, 5002, 5003, 5004, 5005, 5006, 5007, 5008, 5009, 5010, 6001, 6002, 6003, 6004
 6005, 6006, 6007, 6008, 6009, 6010, 7001, 7002, 7003, 7004, 7005, 7006, 7007, 7008, 7009, 7010
 8001, 8002, 8003, 8004, 8005, 8006, 8007, 8008, 8009, 8010, 9001, 9002, 9003, 9004, 9005, 9006
 9007, 9008, 9009, 9010
*Surface, type=ELEMENT, name=s_Surf-1
_s_Surf-1_S3, S3
** Constraint: Constraint-1
*Coupling, constraint name=Constraint-1, ref node=p, surface=s_Surf-1
*Kinematic
*End Assembly
** MATERIALS
*Material, name=Material-1
*Elastic
 2e+11, 0.3
*DSA CONTROLS, FORMULATION=INCREMENTAL
** BOUNDARY CONDITIONS
** Name: BC-1 Type: Symmetry/Antisymmetry/Encastre
*Boundary
Set-1, ENCASTRE
** STEP: Step-1
*Step, name=Step-1, nlgeom=NO, inc=10000, DSA=YES
*Static
1., 1., 1e-05, 1.
** LOADS
** Name: Load-1   Type: Concentrated force
*Cload
p, 2, <Pi>.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*DESIGN RESPONSE
*NODE RESPONSE
RF,
*Element RESPONSE
S,
*End Step
ABAQUS
全部回答 (2)
橙子_2631 2022年3月13日
后来发现关键字*Cload属下的参数<Pi>后面带了句点".",可能是浮点参数<Pi>(查了帮助文档和辅导书籍说该参数必须是浮点数,可能我输入了整数程序自动转化为浮点数),浮点数小数点又与后面的句点"."混淆。inp文件此处的句点改为逗号",",即<Pi>.改为<Pi>,然后把前面"*PARAMETER Pi=-10000"的整数"-10000"改为浮点数"-10000.0"就可以顺利计算出结果了。
2022年3月13日
评论 2 点赞 3
橙子_2631 2022年2月7日
在dat文件里面的报错信息摘选如下,知道里面英文的意思但改了很多次还是没用,请教各位如何解决谢谢
                     ***COMMENT: STARTING PARAMETER EVALUATION
                     ***COMMENT: STARTING PARAMETER SUBSTITUTION
     LINE     5
                     ***ERROR:   INVALID SYNTAX IN THE USAGE OF DESIGN PARAMETER Pa.
                                 CHECK DATA LINES ASSOCIATED WITH THE FOLLOWING KEYWORD:
                                 *CLOAD
     LINE    10      ***ERROR:   SUBSTITUTION OF DESIGN GRADIENTS FAILED
                     ***ERROR:   SUBSTITUTION OF PARAMETERS FAILED
                     ***COMMENT: EVALUATION AND SUBSTITUTION OF PARAMETERS COMPLETED
2022年2月7日
相似问题
查看全部
  • ABAQUS问题? 4个回答
    我用的是UMAT子程序,出现以下问题: The executable standard.exe aborted with system error code 1073740940. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error mess
  • 用inp文件定义局部坐标各向异性报错怎么解决? 暂无回答
    我定义了一个8单元结构,在inp文件里想通过节点建立局部坐标系来赋予各向异性材料方向,但是导入之后会有“ValueError: operands could not be broadcast together with shapes (0,) (3,) This occurred while creating part level orientation ORI-1. The region in
  • inp文件引入接触出错,请问是什么原因? 4个回答
    错误信息: *CONTACT PROPERTY ASSIGNMENT CAN ONLY REFERENCE SURFACE INTERACTIONS WHICH ARE DEFINED AS MODEL DATA. SEE THE SURFACE INTERACTION NAMED INTPROP-1. inp文件: *Heading ** Job name: Job-1 Model name:
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
step by step 教你如何在abaqus中使用实体单元和连接单元建立螺栓连接
幻想飞翔 幻想飞翔
¥30
陈东陈 陈东陈
免费
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
