顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
inp文件引入接触出错,请问是什么原因? 20
浏览: 2734 回答: 3
错误信息:
*CONTACT PROPERTY ASSIGNMENT CAN ONLY REFERENCE SURFACE INTERACTIONS WHICH ARE DEFINED AS MODEL DATA.  SEE THE SURFACE INTERACTION NAMED INTPROP-1.
inp文件:
*Heading
** Job name: Job-1 Model name: Model-1
** Generated by: Abaqus/CAE 2016
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Part-1
*Node
      1,           0.,           0.,           0.
*Nset, nset=Set-1, generate
 1,  1,  1
*Element, type=PD3D, elset=Set-1_Inertia-1_
1, 1
*DISCRETE SECTION, elset=Set-1_Inertia-1_,DENSITY=2000,ALPHA=0
0.2
*DISCRETE ELASTICITY
200E12,0.3
*SURFACE,NAME=face1,TYPE=ELEMENT
1,
*End Part
*Part, name=Part-2
*Node
*Element, type=R3D4
*Node
     67, -0.0399999991, -0.0199999996,           0.
*Nset, nset=Part-2-RefPt_, internal
67,
*Elset, elset=Part-2, generate
  1,  50,   1
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
*End Instance
*Instance, name=Part-2-1, part=Part-2
 -1.38777878078145e-17,        -0.02,         0.02
 -1.38777878078145e-17,        -0.02,         0.02,           1.,        -0.02,         0.02,          90.
*End Instance
*Nset, nset=Set-1, instance=Part-2-1, generate
  1,  66,   1
*Elset, elset=Set-1, instance=Part-2-1, generate
  1,  50,   1
*Rigid Body, ref node=Part-2-1.Part-2-RefPt_, elset=Part-2-1.Part-2
*End Assembly
** BOUNDARY CONDITIONS
** Name: BC-1 Type: Symmetry/Antisymmetry/Encastre
*Boundary
Set-1, ENCASTRE
** PREDEFINED FIELDS
** Name: Predefined Field-1   Type: Velocity
*Initial Conditions, type=VELOCITY
Part-1-1.Set-1, 1, 0.
Part-1-1.Set-1, 2, -0.1
Part-1-1.Set-1, 3, 0.
** STEP: Step-1
*Step, name=Step-1, nlgeom=YES
*Dynamic, Explicit
, 1.
*Bulk Viscosity
0.06, 1.2
*SURFACE INTERACTION,NAME=IntProp-1
*SURFACE BEHAVIOR,PRESSURE-OVERCLOSURE=Hertz
9e13
*Contact, op=NEW
*Contact Inclusions, ALL EXTERIOR
*Contact Property Assignment
 ,  , IntProp-1
** OUTPUT REQUESTS
*Restart, write, number interval=1, time marks=NO
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
ABAQUS inp 接触
全部回答 (1)
君成序 2019年4月29日
把接触属性和通用接触放在step上面。
2019年4月29日
评论 3 点赞 1
相似问题
查看全部
  • inp文件中已经删除相应单元,显示未定义属性? 1个回答
    part-1只留下一个PD3D单元,其余都删了,为什么还会说没定义属性 error信息: 1 elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection. inp文件: *Heading ** Job name: Job-2 Mo
  • abaqusDSA设计敏感性分析修改inp Solver Input File Processor? 5个回答
    请教各位大佬,用dsa设计敏感度分析功能做悬臂梁敏感度分析,inp文件用记事本修改后提交,数据检查能过,但是然后立即出现solver input file processor exited with an error,修改了几次还是有问题。请教一下如何解决,谢谢! 悬臂梁inp文件如下百度网盘: 链接:https://pan.baidu.com/s/12kigjtldkkdfog9bpqbtgg
  • ABAQUS问题? 4个回答
    我用的是UMAT子程序,出现以下问题: The executable standard.exe aborted with system error code 1073740940. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error mess
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
abaqus埋地管道受力分析
abaqus埋地管道受力分析
冷月 冷月
¥25
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
如何为您的应用选择合适的传声器
如何为您的应用选择合适的传声器
HBK声学与振动 HBK声学与振动
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
Altair FlowSimulator一维流体仿真分析软件介绍&模型搭建案例分享
ALTAIR ALTAIR
免费
