顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
用inp文件定义局部坐标各向异性报错怎么解决? 110
浏览: 2833
我定义了一个8单元结构,在inp文件里想通过节点建立局部坐标系来赋予各向异性材料方向,但是导入之后会有“ValueError: operands could not be broadcast together with shapes (0,) (3,)  This occurred while creating part level orientation ORI-1. The region in question will not be imported. ”的提示报错,提示我创建局部坐标系出错,下面是我的inp文件:
*Heading
** Job name: Job-1 Model name: Model-1
** Generated by: Abaqus/CAE 2020
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Part-1
*Node
      1, -0.00999999978, -0.00999999978, 0.0199999996
      2, -0.00999999978,           0., 0.0199999996
      3, -0.00999999978, 0.00999999978, 0.0199999996
      4, -0.00999999978, -0.00999999978, 0.00999999978
      5, -0.00999999978,           0., 0.00999999978
      6, -0.00999999978, 0.00999999978, 0.00999999978
      7, -0.00999999978, -0.00999999978,           0.
      8, -0.00999999978,           0.,           0.
      9, -0.00999999978, 0.00999999978,           0.
     10,           0., -0.00999999978, 0.0199999996
     11,           0.,           0., 0.0199999996
     12,           0., 0.00999999978, 0.0199999996
     13,           0., -0.00999999978, 0.00999999978
     14,           0.,           0., 0.00999999978
     15,           0., 0.00999999978, 0.00999999978
     16,           0., -0.00999999978,           0.
     17,           0.,           0.,           0.
     18,           0., 0.00999999978,           0.
     19, 0.00999999978, -0.00999999978, 0.0199999996
     20, 0.00999999978,           0., 0.0199999996
     21, 0.00999999978, 0.00999999978, 0.0199999996
     22, 0.00999999978, -0.00999999978, 0.00999999978
     23, 0.00999999978,           0., 0.00999999978
     24, 0.00999999978, 0.00999999978, 0.00999999978
     25, 0.00999999978, -0.00999999978,           0.
     26, 0.00999999978,           0.,           0.
     27, 0.00999999978, 0.00999999978,           0.
*Element, type=C3D8R
1, 10, 11, 14, 13,  1,  2,  5,  4
2, 11, 12, 15, 14,  2,  3,  6,  5
3, 13, 14, 17, 16,  4,  5,  8,  7
4, 14, 15, 18, 17,  5,  6,  9,  8
5, 19, 20, 23, 22, 10, 11, 14, 13
6, 20, 21, 24, 23, 11, 12, 15, 14
7, 22, 23, 26, 25, 13, 14, 17, 16
8, 23, 24, 27, 26, 14, 15, 18, 17
*Nset, nset=Set-1, generate
  1,  27,   1
*Elset, elset=Set-1, generate
 1,  8,  1
*Orientation, name=Ori-1, system=Z RECTANGULAR
1,13,4
1,0
** Region: (Section-1:Picked), (Material Orientation:element-1)
*Elset, elset=_I1
1,
** Section: Section-1
*Solid Section, elset=_I1, orientation=Ori-1, material=Material-1
*Orientation, name=Ori-2, system=Z RECTANGULAR
2,14,5
1,0
** Region: (Section-1:Picked), (Material Orientation:element-2)
*Elset, elset=_I2
2,
*Solid Section, elset=_I2, orientation=Ori-2, material=Material-1
*Orientation, name=Ori-3, system=Z RECTANGULAR
4,16,7
1,0
*Elset, elset=_I3
3,
*Solid Section, elset=_I3, orientation=Ori-3, material=Material-1
*Orientation, name=Ori-4, system=Z RECTANGULAR
5,17,8
1,0
*Elset, elset=_I4
4,
*Solid Section, elset=_I4, orientation=Ori-4, material=Material-1
*Orientation, name=Ori-5, system=Z RECTANGULAR
10,22,13
1,0
*Elset, elset=_I5
5,
*Solid Section, elset=_I5, orientation=Ori-5, material=Material-1
*Orientation, name=Ori-6, system=Z RECTANGULAR
11,23,14
1,0
*Elset, elset=_I6
6,
*Solid Section, elset=_I6, orientation=Ori-6, material=Material-1
*Orientation, name=Ori-7, system=Z RECTANGULAR
13,25,16
1,0
*Elset, elset=_I7
7,
*Solid Section, elset=_I7, orientation=Ori-7, material=Material-1
*Orientation, name=Ori-8, system=Z RECTANGULAR
14,26,17
1,0
*Elset, elset=_I8
8,
*Solid Section, elset=_I8, orientation=Ori-8, material=Material-1
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
*End Instance
*Nset, nset=Set-1, instance=Part-1-1
  1,  2,  3, 10, 11, 12, 19, 20, 21
*Elset, elset=Set-1, instance=Part-1-1
 1, 2, 5, 6
*Elset, elset=_Surf-1_S4, internal, instance=Part-1-1, generate
 2,  8,  2
*Surface, type=ELEMENT, name=Surf-1
_Surf-1_S4, S4
*End Assembly
** MATERIALS
*Material, name=Material-1
*Elastic, type=ORTHOTROPIC
 1.37485e+08, 7.94493e+07, 1.37485e+08, 4.44715e+07, 4.44715e+07, 6.29233e+08,       1e+08,       1e+08
     3.2e+07,
** STEP: Step-1
*Step, name=Step-1, nlgeom=NO
*Static
1., 1., 1e-05, 1.
** BOUNDARY CONDITIONS
** Name: BC-1 Type: 对称/反对称/完全固定
*Boundary
Set-1, ENCASTRE
** LOADS
** Name: Load-1   Type: Pressure
*Dsload
Surf-1, P, 200000.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
请问我的错误在哪里呢
CAE ABAQUS
全部回答 (0)
相似问题
查看全部
  • abaqusDSA设计敏感性分析修改inp Solver Input File Processor? 5个回答
    请教各位大佬,用dsa设计敏感度分析功能做悬臂梁敏感度分析,inp文件用记事本修改后提交,数据检查能过,但是然后立即出现solver input file processor exited with an error,修改了几次还是有问题。请教一下如何解决,谢谢! 悬臂梁inp文件如下百度网盘: 链接:https://pan.baidu.com/s/12kigjtldkkdfog9bpqbtgg
  • Abaqus 帮助文档例子没有设置重力加速度也可以进行跌落? 4个回答
    在Abaqus帮助文档里面,有一个 circuit board drop test 的例子,为什么里面没有设置重力加速度也可以进行跌落?只有初速度? 如果想继续分析它二次跌落,是不是 一定 要加重力加速度? circuit.inp *HEADING Circuit board drop test -- 1.0 meter drop SI units (kg, m, s, N) *SYSTEM 0.
  • ABAQUS问题? 4个回答
    我用的是UMAT子程序,出现以下问题: The executable standard.exe aborted with system error code 1073740940. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error mess
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
Isight_Adams Car联合仿真_suspension案例--excle方式
东邪不邪 东邪不邪
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
