abaqus中.sta文件这些关于接触的话什么意思呀,看的模模糊糊不是太理解?
INFORMATION REGARDING INITIAL CONTACT PAIR OVERCLOSURES THAT Abaqus/Explicit
WILL ATTEMPT TO RESOLVE WITH STRAIN-FREE ADJUSTMENTS TO POSITIONS OF
DEFORMABLE
SLAVE NODES Step 1
Maximum overclosure between surface ASSEMBLY_SURF-PIN and surface
ASSEMBLY_SURF-DISC is 1.62371E-02.
Maximum adjustment for initial overclosure is: 1.62371E-02 at node 12 of instance XINPIN_R80.
***NOTE: You can view the deformed configuration due to the resolution of
initial overclosures. In increment 0, draw the deformed shape or
draw a symbol plot of vector displacements.
More detailed overclosure adjustment information can be found in the message file.
INFORMATION REGARDING UNRESOLVED INITIAL CONTACT PAIR OVERCLOSURES FOR
SLAVE NODES Step 1
***WARNING: For contact pairs that are not tied, unresolved initial
overclosures will result in initial accelerations on the order of
the penetration distance divided by the time increment squared,
which can lead to significant mesh distortion. These overclosures
can be avoided by user adjustment of the mesh.
ASSEMBLY_SURF-DISC is 2.87868E-19.
技术邻问答 2017年11月16日
