顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
abaqus做仿真提示的错误? 1760
浏览: 4295 回答: 13
Abaqus中先算螺栓预紧力后算冲击,如何设置如下:
1. 我是先用general static分析步算螺栓预紧力的,算完之后改成dynamic explicit分析步进行求解,请问这个思路是对的吗?
2. 在求解螺栓预紧力的时候我也设置了restart
3. 算完之后的文件如下:
4.然后另存模型,修改分析步为dynamic explicit,删除load边界条件,也就是螺栓预紧力,还修改了model attributes和load 模块里面的predifined filed
4.job里面是这样设置的:
5.提交计算提示错误
The slave surface assembly_part21-1_surf-igbt-base does not exist.
Surface assembly_part21-1_surf-igbt-base not found
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-cooler but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part1-1_surf-cooler-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-1 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-1_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-2 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-2_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-3 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-3_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-4 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-4_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-5 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-5_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_part22(dizuo)-1_surf-base-6 but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Contact pair references surface/node-based surface/analytical rigid surface assembly_bolt-6_surf-bolt-base but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined on the collapsed faces
Analysis Input File Processor exited with an error.
该怎么办呢?我定义接触了啊,看了一下都没有问题
求各位大神指点一二,在此拜谢!
ABAQUS 结构CAE 显式动力学及仿真 机械电子 有限元理论及编程
全部回答 (10)
喻小泉 2023年12月14日
要在装配体里重新建立表面,将部件里的表面删掉
2023年12月14日
评论 点赞 1
林丽 2017年11月22日
不是 应该就是你用的这个predefined field, 只是你要分开成两个cae文件来做,不是在同一个里面。你先计算第一步,得到的odb文件里面的应力分布作为第二步dynamic分析的初识应力场。
2017年11月22日
评论 点赞 1
走过繁华四季的美好 2017年12月10日
你这个是面定义的有问题,不连续的不能选,接触要分开定义,我遇到过这样的错误,有问题可以加我qq交流
2017年12月10日
已采纳 评论 1 点赞
林丽 2017年11月22日
不是重启动分析
2017年11月22日
善哉善哉 2017年11月22日
@一只攻城狮
2017年11月22日
善哉善哉 2017年11月22日
@ 一只攻城狮
2017年11月22日
善哉善哉 2017年11月22日
@ 一只攻城狮
2017年11月22日
善哉善哉 2017年11月22日
@一只攻城狮,是这样的吗
2017年11月22日
善哉善哉 2017年11月22日
是这样的吗
2017年11月22日
林丽 2017年11月22日
不是用restart 要用import 或者都用dynamic的分析方式啊
2017年11月22日
相似问题
查看全部
  • abaqus出现报错? 5个回答
    在分析时abaqus出现Error in job FJF-explicit: CONTACT PAIR REFERENCES SURFACE/NODE-BASED SURFACE/ANALYTICAL RIGID SURFACE ASSEMBLY_PART-2-1_LOWPLATE-UPPLATE-GEO BUT THIS SURFACE/NODE-BASED SURFACE/ANALYTICAL
  • 请问这个错误怎么改 1个回答
    Contact pair references surface/node-based surface/analytical rigid surface assembly_cutter but this surface/node-based surface/analytical rigid surface has not been defined or this surface is defined
  • ABAQUS问题 2个回答
    error:Too many attempts made for this increment Abaqus/Standard Analysis exited with an error - Please see the message file for possible error messages if the file exists. wanning:Path based tracking
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
Isight_Adams Car联合仿真_suspension案例--excle方式
东邪不邪 东邪不邪
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
