顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
abaqus动力显式模拟挤压,在运行一定过程,网格畸变过大,报错,想了解如何解决? 24
浏览: 4615 回答: 19 采纳: 1
报错信息为
The elements in element set ErrElemZeroALEMass-Step1 have zero or negative mass.
There are a total of 7 excessively distorted elements
The elements contained in element set ErrElemExcessDistortion-Step1 have distorted excessively.
以下是status文件相关信息
***WARNING: Master surface ASSEMBLY_SURF-CU-3 of contact pair # 5 contains
           facets with out-of-plane warping of at least 20.000 degrees in
           increment 22480. Large warping that develops during an analysis
           often corresponds to severe distortion of the underlying elements.
           It may be appropriate to rerun the analysis with a refined mesh.
   22776 5.442E-01 5.442E-01 00:39:14 2.400E-05       5853 7.245E+06 -3.111E+08 9.999E+05
INSTANCE WITH CRITICAL ELEMENT: P2CULAYER-1
***ERROR: Zero or negative mass in element number P2CULAYER-1.54179
***ERROR: Zero or negative mass in element number P2CULAYER-1.54186
***ERROR: Zero or negative mass in element number P2CULAYER-1.55131
***ERROR: Excessive distortion of element number 54186 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55131 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55369 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55376 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55377 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55383 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55384 of instance P2CULAYER-1
***WARNING: Mechanical penalty contact between surfaces ASSEMBLY_M_SURF-1 and
           ASSEMBLY_S_SURF-1 is causing a 72.434% reduction in the time
           increment.
***ERROR: There are a total of 7 excessively distorted elements
  The following checklist may be helpful in diagnosing the error:
   1. Check for poor initial mesh definition.
   2. Check the parameters used for ALE. Reducing the number of
      increments between ALE or increasing the number of sweeps in each ALE
      increment may yield a better mesh.
   3. Check contact definitions for problems such as excessive initial
      overclosure or unrealistic tied definition between contact pairs.
      A vector plot of velocities or accelerations will usually help to
      identify contact problems.
   4. Check stiffness (elastic modulus) and mass (density) definitions for
      consistent units and verify that the combination is reasonable.
   5. Check the boundary conditions for an excessive loading rate. The
      *DIAGNOSTICS, DEFORMATION SPEED=DETAIL option may be used to obtain
      detailed diagnostics information.
   6. Check the current status of the structure to see if it has
      totally failed.
   7. A dashpot or a very stiff spring may cause the analysis to go unstable.
      The *DYNAMIC, DIRECT option may be used to control the time increment
      directly.
***ERROR: The fatal error will generate a new field output in the last
         increment. All variables applicable to the current procedure and
         material type(s) will be written to the output database.
***ERROR: Excessive distortion of element number 47173 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47179 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47185 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47186 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47187 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47939 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47946 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 48163 of instance P2CULAYER-1
全部回答 (2)
不正经CAE工程师 2025年2月18日
报错的原因是网格畸变。如果是3D模型的话,建议使用欧拉法模拟,如果是2D模型,那么需要好好设计初始网格,或者使用ALE算法
2025年2月18日
已采纳 评论 16 点赞 1
momo_2899 2025年2月20日
建议使用ALE来解决
2025年2月20日
相似问题
查看全部
  • ABAQUS问题? 4个回答
    我用的是UMAT子程序,出现以下问题: The executable standard.exe aborted with system error code 1073740940. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error mess
  • abaqus 存在distorted excessively,如何解决? 3个回答
    在abaqus仿真中,楔块设置了边界载荷,当载荷是汉宁窗调制的正弦信号,在400kHz频率,模型就能正常允许,一旦改变频率就会报错。改变了网格,和时间步长也没有用,求大神解答 Error in job Job-28: The elements contained in element set ErrElemExcessDistortion-Step1 have distorted excessiv
  • 请教一下abaqus仿真这个问题怎么解决? 1个回答
    Error in job Job-1: The elements contained in element set ErrElemExcessDistortion-Step1 have distorted excessively. Error in job Job-1: Print-out suppressed for subsequent distorted elements Error in
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
step by step 教你如何在abaqus中使用实体单元和连接单元建立螺栓连接
幻想飞翔 幻想飞翔
¥30
陈东陈 陈东陈
免费
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
abaqus埋地管道受力分析
abaqus埋地管道受力分析
冷月 冷月
¥25
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
