顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
钢管混凝土梁柱节点?
浏览: 3059 回答: 1
使用的ABAQUS模拟
计算中断的错误信息:
Normal cannot be computed in 8 elements. The nodal coordinates may be incorrect or the element aspect ratio may exceed 1000 to 1. The elements have been identified in element set ErrElemNormal.
64 nodes are used more than once as a slave node in *TIE keyword. These constraints are not removed either due to the presence of *CONSTRAINT CONTROLS,NO CHANGES keyword or because removing the constraints might affect the model. The nodes have been identified in node set ErrNodeOverconTieSlave.
The geometry of 8 elements is too distorted. Check the nodal coordinates or node numbering on elements identified in element set ErrElemDistorted.
The area of 6 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. The elements have been identified in element set ErrElemAreaSmallNegZero.
Error in defining normal to the element surface at a node in 8 elements. The elements have been identified in element set ErrElemShellNormal.
The yield stress must not be zero
Analysis Input File Processor exited with an error.
这个错误原因是哪呢?什么意思呢?
像ErrElemNomal、ErrElemDistored、WarnElemDistored、、、这些点的问题怎么解除呢?求大神指教
ABAQUS 结构CAE
全部回答 (1)
小月 2017年1月9日
初步判断,是由于绑定时,主从面间距过大,导致从面节点被拖的太远,引起网格畸变,计算失败!
2017年1月9日
相似问题
查看全部
  • abaqus 钢结构先线单元建模出现下面这种歌报错怎么修改呀? 1个回答
    Normal cannot be computed in 20 elements. The nodal coordinates may be incorrect or the element aspect ratio may exceed 1000 to 1. The elements have been identified in element set ErrElemNormal. Error
  • 各位大佬,新手abaqus分析错误,求教,怎么解决啊 8个回答
    in keyword *COUPLING, file "Job-2.inp", line 35443: Unknown assembly set M_SET-5 Node set assembly_m_set-5 has not been defined Unable to locate node set assembly_m_set-5. The node set must have been
  • 大佬帮忙看看问题出在哪里了,感谢? 1个回答
    For two-dimensional models, if a non-unity thickness is specified for two-dimensional solid elements and these elements are involved in an interaction such as contact, the same thickness should be spe
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
如何为您的应用选择合适的传声器
如何为您的应用选择合适的传声器
HBK声学与振动 HBK声学与振动
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
Altair FlowSimulator一维流体仿真分析软件介绍&模型搭建案例分享
ALTAIR ALTAIR
免费
教你用10分钟快速完成自行车结构CAE分析!
技术邻直播 技术邻直播
免费
