顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
abaqus 钢结构先线单元建模出现下面这种歌报错怎么修改呀?
浏览: 3083 回答: 1
 Normal cannot be computed in 20 elements. The nodal coordinates may be incorrect or the element aspect ratio may exceed 1000 to 1. The elements have been identified in element set ErrElemNormal.
Error in job Job-1: 20 elements have zero length. The elements have been identified in element set ErrElemZeroLength.
Error in job Job-1: 20 elements have small or zero length. The elements have been identified in element set ErrElemLenSmallNegZero.
Error in job Job-1: Error in defining or computing beam section normal in 20 elements. The elements have been identified in element set ErrElemBeamSecNormal.
Error in job Job-1: The beam cross-section direction vectors coincide at a node in 20 elements. The elements have been identified in element set ErrElemBeamSecDirVect.
ABAQUS ABAQUS土木 asp UT ME
全部回答 (1)
zarhin 2023年8月16日
检查下截面方向
2023年8月16日
相似问题
查看全部
  • ABAQUS计算过程报错,如何解决? 1个回答
    Job Job-2: Analysis Input File Processor completed successfully. Error in job Job-2: Too many attempts made for this increment Job Job-2: Abaqus/Standard aborted due to errors. Error in job Job-2: Aba
  • 谁知道abaqus零主轴怎么办,求求各位大神指导 2个回答
    Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_1. Solver problem. Zero pivot when processing D.O.F. 3 of 1 n
  • abaqus导入应力计算报错,怎么改还是不对,希望哪位老师帮着看一下什么原因? 1个回答
    错误如下 Error in job Job-1: The volume of 3 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that a
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
step by step 教你如何在abaqus中使用实体单元和连接单元建立螺栓连接
幻想飞翔 幻想飞翔
¥30
陈东陈 陈东陈
免费
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
