顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
ABAQUS计算过程报错,如何解决?
浏览: 4068 回答: 1
Job Job-2: Analysis Input File Processor completed successfully.
Error in job Job-2: Too many attempts made for this increment
Job Job-2: Abaqus/Standard aborted due to errors.
Error in job Job-2: Abaqus/Standard Analysis exited with an error - Please see the  message file for possible error messages if the file exists.
Job Job-2 aborted due to errors.
Output request damaget is not available for the material for element type c3d8
Output request damaget is not available for the material for element type s4
166117 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
The aspect ratio for 130 elements exceeds 100 to 1. The elements have been identified in element set WarnElemAspectRatio.
1 elements are curved/warped. The angle subtended between the average element normal and a nodal normal exceeds 10 degrees. Mesh refinement is recommended. The elements have been identified in element set WarnElemWarped.
There are 116 unconnected regions in the model.
The plasticity/creep/connector friction algorithm did not converge at 800579 points
The plasticity/creep/connector friction algorithm did not converge at 1142412 points
The plasticity/creep/connector friction algorithm did not converge at 1238922 points
The plasticity/creep/connector friction algorithm did not converge at 1270393 points
The plasticity/creep/connector friction algorithm did not converge at 1278392 points
请教大佬如何解决
CAE ABAQUS
全部回答 (1)
TechmanLXS 2023年10月27日
不收敛,去你的msg看下详细信息。
2023年10月27日
相似问题
查看全部
  • abaqus桩土模拟地应力平衡? 2个回答
    请问一些,在进行桩土模拟时, A geostatic procedure with maximum displacement tolerances is supported only for the following materials: elastic, porous elastic, extended cam-clay plasticity model and mohr-coulomb pl
  • 关于abaqus计算不收敛的求助!! 暂无回答
    本人在模拟一个钢筋混凝土框架结构在竖向荷载及水平周期反复荷载作用时一直出现如下警告,然后计算一直不收敛。还望各位大神指点。模型在下方。 VF.zip Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation)
  • abaqus这是什么意思,最后算不过去,怎么解决? 6个回答
    The plasticity/creep/connector friction algorithm did not converge at 1 points The plasticity/creep/connector friction algorithm did not converge at 1 points The plasticity/creep/connector friction al
推荐阅读
ansys结构动力学仿真
ansys结构动力学仿真
技术邻小李 技术邻小李
¥150
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
abaqus埋地管道受力分析
abaqus埋地管道受力分析
冷月 冷月
¥25
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
如何为您的应用选择合适的传声器
如何为您的应用选择合适的传声器
HBK声学与振动 HBK声学与振动
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
Altair FlowSimulator一维流体仿真分析软件介绍&模型搭建案例分享
ALTAIR ALTAIR
免费
