顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
abaqus桩土模拟地应力平衡?
浏览: 4666 回答: 2
请问一些,在进行桩土模拟时,
A geostatic procedure with maximum displacement tolerances is supported only for the following materials: elastic, porous elastic, extended cam-clay plasticity model and mohr-coulomb plasticity model. In general, the use of other materials with this procedure may lead to poor convergence or no convergence of the analysis.
A geostatic procedure with maximum displacement tolerances is supported only for continuum elements with pore pressure degree of freedom and the corresponding stress/displacement continuum elements. In general, the use of other elements with this procedure may lead to poor convergence or no convergence of the analysis.
1146 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
The plasticity/creep/connector friction algorithm did not converge at 270 points
The plasticity/creep/connector friction algorithm did not converge at 174 points
The plasticity/creep/connector friction algorithm did not converge at 48 points
老是出现上面的问题怎么解决呀?
全部回答 (2)
一只本泽马 2020年7月17日
你的某一个分析步可能是地应力分析步,尝试一下改为静力通用
2020年7月17日
评论 点赞 1
红日当空q3120210076 2020年3月29日
可以参考我的技术邻视频 关于解决桩土地应力平衡问题
2020年3月29日
评论 点赞 1
相似问题
查看全部
  • 关于abaqus计算不收敛的求助!! 暂无回答
    本人在模拟一个钢筋混凝土框架结构在竖向荷载及水平周期反复荷载作用时一直出现如下警告,然后计算一直不收敛。还望各位大神指点。模型在下方。 VF.zip Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation)
  • abaqus这是什么意思,最后算不过去,怎么解决? 6个回答
    The plasticity/creep/connector friction algorithm did not converge at 1 points The plasticity/creep/connector friction algorithm did not converge at 1 points The plasticity/creep/connector friction al
  • ABAQUS计算过程报错,如何解决? 1个回答
    Job Job-2: Analysis Input File Processor completed successfully. Error in job Job-2: Too many attempts made for this increment Job Job-2: Abaqus/Standard aborted due to errors. Error in job Job-2: Aba
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
step by step 教你如何在abaqus中使用实体单元和连接单元建立螺栓连接
幻想飞翔 幻想飞翔
¥30
陈东陈 陈东陈
免费
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
abaqus埋地管道受力分析
abaqus埋地管道受力分析
冷月 冷月
¥25
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
