顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
谁知道abaqus零主轴怎么办,求求各位大神指导
浏览: 4340 回答: 2
Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_1.
Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_4.
Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_5.
<Warning><message type="string">Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_1.</message><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Warning>
<Status><step type="integer">2</step><increment type="integer">1</increment><attempts type="string"> 1U</attempts><severe type="integer">8</severe><equilibrium type="integer">0</equilibrium><iterations type="integer">8</iterations><totalTime type="float">1</totalTime><stepTime type="float">0</stepTime><timeIncrement type="float">1</timeIncrement><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Status>
<Status><step type="integer">2</step><increment type="integer">1</increment><attempts type="string"> 2U</attempts><severe type="integer">13</severe><equilibrium type="integer">0</equilibrium><iterations type="integer">13</iterations><totalTime type="float">1</totalTime><stepTime type="float">0</stepTime><timeIncrement type="float">0.25</timeIncrement><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Status>
<Status><step type="integer">2</step><increment type="integer">1</increment><attempts type="string"> 3U</attempts><severe type="integer">13</severe><equilibrium type="integer">0</equilibrium><iterations type="integer">13</iterations><totalTime type="float">1</totalTime><stepTime type="float">0</stepTime><timeIncrement type="float">0.0625</timeIncrement><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Status>
<Warning><message type="string">Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_4.</message><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Warning>
<Status><step type="integer">2</step><increment type="integer">1</increment><attempts type="string"> 4U</attempts><severe type="integer">13</severe><equilibrium type="integer">0</equilibrium><iterations type="integer">13</iterations><totalTime type="float">1</totalTime><stepTime type="float">0</stepTime><timeIncrement type="float">0.015625</timeIncrement><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Status>
<Warning><message type="string">Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_5.</message><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Warning>
<Error><message type="string">Process terminated by external request (SIGTERM or SIGINT received).</message><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Error>
<Interrupted><message type="string">Analysis interrupted by external signal</message><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Interrupted>
<ERROR><message type="string">Abaqus/Standard Analysis exited with an error - Please see the  message file for possible error messages if the file exists.</message><jobName type="string">Job-77zyf</jobName></ERROR><JOB_RTED><message type="string">Abaqus/Standard Analysis exited with an error - Please see the  message file for possible error messages if the file exists.</message><jobName type="string">Job-77zyf</jobName></JOB_RTED></msgwrapper>
ABAQUS
全部回答 (2)
北望逸尘 2021年6月23日
零主元有可能是过约束,这个要结合模型各个模块对比分析才能解决
2021年6月23日
李少飞 2021年6月23日
检查一下模型的相互作用模块,可能是过约束了
2021年6月23日
相似问题
查看全部
  • abaqus monitor的問題,需如何改善? 6个回答
    You have entered a zero or negative density value. Abaqus allows non-physical data; however, most applications expect a positive density value and greater than 1.00000e-36 . 4 nodes associated with ri
  • 为什么降温法模拟钢绞线(桁架单元)后处理云图中会这样? 2个回答
    Solver problem. Zero pivot when processing D.O.F. 2 of 4 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_1_1_1_1. Solver problem. Zero pivot when processing D.O.F. 1 of 6 n
  • 【ABAQUS--设置连接器】梁两端设置连接器不收敛? 4个回答
    麻烦大家指导下~~~~ ABAQUS模拟杆件系统中,一个杆两段均设置非线性轴向连接器,一开始就不收敛算不过去。尝试过一端连接器,一段MPC-tie连接可以收敛,希望大神指导下~~ 错误警告: One or more thickness of the box section is greater than 0.1 of the cross section dimension. The torsion
推荐阅读
ansys结构动力学仿真
ansys结构动力学仿真
技术邻小李 技术邻小李
¥150
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
Isight_Adams Car联合仿真_suspension案例--excle方式
东邪不邪 东邪不邪
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
