顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
为什么降温法模拟钢绞线(桁架单元)后处理云图中会这样?
浏览: 2526 回答: 2
Solver problem. Zero pivot when processing D.O.F. 2 of 4 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_1_1_1_1.
Solver problem. Zero pivot when processing D.O.F. 1 of 6 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_1_1_2_1.
Solver problem. Zero pivot when processing D.O.F. 2 of 6 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_1_1_2_1.
Solver problem. Zero pivot when processing D.O.F. 3 of 4 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_1_1_2_1.
Solver problem. Zero pivot when processing D.O.F. 1 of 6 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_1_1_3_1.
Solver problem. Zero pivot when processing D.O.F. 2 of 6 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_1_1_3_1.
Solver problem. Zero pivot when processing D.O.F. 3 of 4 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_1_1_3_1.
Solver problem. Zero pivot when processing D.O.F. 1 of 5 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_1_1_4_1.
Solver problem. Zero pivot when processing D.O.F. 2 of 5 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_1_1_4_1.
Solver problem. Zero pivot when processing D.O.F. 3 of 3 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_1_1_4_1.
全部回答 (1)
SnowWave02 2021年4月3日
是不是杆单元约束不够?杆单元没法固支的,只能约束平动
2021年4月3日
相似问题
查看全部
  • abaqus monitor的問題,需如何改善? 6个回答
    You have entered a zero or negative density value. Abaqus allows non-physical data; however, most applications expect a positive density value and greater than 1.00000e-36 . 4 nodes associated with ri
  • 谁知道abaqus零主轴怎么办,求求各位大神指导 2个回答
    Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_1. Solver problem. Zero pivot when processing D.O.F. 3 of 1 n
  • 请问一下,下面这些警告信息怎么处理? 2个回答
    请问一下,下面这些警告信息怎么处理?? Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other cons
推荐阅读
ansys结构动力学仿真
ansys结构动力学仿真
技术邻小李 技术邻小李
¥150
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
Isight_Adams Car联合仿真_suspension案例--excle方式
东邪不邪 东邪不邪
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
