顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
请问一下,下面这些警告信息怎么处理?
浏览: 12686 回答: 2
请问一下,下面这些警告信息怎么处理??
Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other constraint including mpcs, rigid bodies, etc.
For *tie pair (assembly__pickedsurf69-assembly__pickedsurf68), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf71-assembly__pickedsurf70), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
MPCS (EXTERNAL or INTERNAL, including those generated from rigid body definitions), KINEMATIC COUPLINGS, AND/OR EQUATIONS WILL ACTIVATE ADDITIONAL DEGREES OF FREEDOM
Boundary conditions are specified on inactive dof of 22 nodes. The nodes have been identified in node set WarnNodeBCInactiveDof.
Solver problem. Zero pivot when processing D.O.F. 1 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_1_97_1_1.
Temperature at 1 nodes has fallen below absolute zero. Increment will be attempted again with a new time increment. The nodes have been identified in node set WarnNodeTempBelowZeroStep1Inc894.
Solver problem. Zero pivot when processing D.O.F. 1 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_1_894_1_2.
ABAQUS 结构CAE 土木工程
全部回答 (2)
林ads 2017年3月8日
能收敛就不需要
2017年3月8日
技术工 2017年3月6日
@一只攻城狮@王琰@林ads@Tony周@崔博士
2017年3月6日
相似问题
查看全部
  • abaqus新手求教???? 1个回答
  • 水下井口局部有限元分析模型报错及警告问题求解? 暂无回答
    用ABAQUS进行分析时,总是算了一下就出错,看了一下warning和Error主要是这些问题,求问怎么解决? 1.5624 nodes have dof on which incorrect boundary conditions may have been specified. The nodes have been identified in node set WarnNodeBCIncor
  • 关于abaqus计算不收敛的求助!! 暂无回答
    本人在模拟一个钢筋混凝土框架结构在竖向荷载及水平周期反复荷载作用时一直出现如下警告,然后计算一直不收敛。还望各位大神指点。模型在下方。 VF.zip Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation)
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
step by step 教你如何在abaqus中使用实体单元和连接单元建立螺栓连接
幻想飞翔 幻想飞翔
¥30
陈东陈 陈东陈
免费
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
abaqus埋地管道受力分析
abaqus埋地管道受力分析
冷月 冷月
¥25
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
