顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
水下井口局部有限元分析模型报错及警告问题求解?
浏览: 3029
用ABAQUS进行分析时,总是算了一下就出错,看了一下warning和Error主要是这些问题,求问怎么解决?
1.5624 nodes have dof on which incorrect boundary conditions may have been specified. The nodes have been identified in node set WarnNodeBCIncorrectDof.
2.OVERCONSTRAINT CHECKS: THERE ARE 16926 BOUNDARY CONDITIONS SPECIFIED IN THIS MODEL. OVERCONSTRAINT CHECKS FOR BOUNDARY CONDITIONS SPECIFIED ON SLAVE NODES OF RIGID BODIES, OF *TIE OPTIONS, OR OF *COUPLING OPTIONS REQUIRE 7 Mb OF MEMORY. IF THIS IS A PROBLEM, PLEASE TURN OFF OVERCONSTRAINT CHECKS USING *CONSTRAINT CONTROLS, NO CHECKS or INCREASE THE MEMORY USED BY THE PRE-PROCESSOR.
3.MPCS (EXTERNAL or INTERNAL, including those generated from rigid body definitions), KINEMATIC COUPLINGS, AND/OR EQUATIONS WILL ACTIVATE ADDITIONAL DEGREES OF FREEDOM
4.26753 nodes are either missing intersection with their respective master surface or are outside the adjust zone. The nodes have been identified in node set WarnNodeMissMasterIntersect.
5.Slave node 290 instance conducor-1 will not be tied to the master surface assembly_cement-out_cns_. The distance from the master surface is greater than the position tolerance value.
6.SLAVE NODE 4804 INSTANCE LW-1 WILL NOT BE TIED TO THE MASTER SURFACE ASSEMBLY_con top_CNS_. THE DISTANCE FROM THE MASTER SURFACE IS GREATER THAN THE POSITION TOLERANCE VALUE.
7.*tie between surface pair (assembly_conductor-cement_cns_,assembly_cement-out_cns_) may result in unrealistic deformation between the surfaces or large stresses because the master is node-based and no adjustment is specified. Define a surface-based master surface or adjust=yes to avoid this problem.
谢谢
ABAQUS
全部回答 (0)
相似问题
查看全部
  • Abaqus壳单元分析运行终止,报错Too many attempts made for ? 4个回答
    用hypermesh抽取中面划分壳单元后,导入到abaqus中设置进行分析,分析终止只报错Too many attempts made for this increment。 警告内容: For *tie pair (assembly_channel-tie-assembly_base-tie), adjusted nodes with very small adjustments were no
  • 求指导,关于Tie,The distance from the master surface is greater than..... 5个回答
    遇见了下面的问题,苦思冥想了好久也没有解决。ABAQUS 绑定约束 出现以下问题: Slave surface assembly_set-2_cns_ is a node-based surface used with surface to surface approach. In order to obtain improved stress accuracy with this approac
  • 请问一下,下面这些警告信息怎么处理? 2个回答
    请问一下,下面这些警告信息怎么处理?? Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other cons
推荐阅读
ansys结构动力学仿真
ansys结构动力学仿真
技术邻小李 技术邻小李
¥150
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
Isight_Adams Car联合仿真_suspension案例--excle方式
东邪不邪 东邪不邪
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
