顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
abaqus monitor的問題,需如何改善?
浏览: 3103 回答: 6
You have entered a zero or negative density value. Abaqus allows non-physical data; however, most applications expect a positive density value and greater than 1.00000e-36 .
4 nodes associated with rigid bodies have boundary conditions prescribed at nodes other than the reference node. These boundary conditions will be transferred to the associated rigid body reference node.The reference nodes and the dependent nodes have been identified in node set WarnNodeOverconBoundRB.
Nodes belonging to 2 RIGID BODIES have boundary conditions prescribed at nodes other than the reference node. These boundary conditions indicate the rigid bodies cannot rotate about certain axes. Zero rotational boundary conditions have been added to these reference nodes.The reference nodes have been identified in node set WarnNodeOverconBoundRBRot.
Solver problem. Zero pivot when processing node ASSEMBLY.1 D.O.F. 4.
Solver problem. Zero pivot when processing node ASSEMBLY.1 D.O.F. 5.
Solver problem. Zero pivot when processing node 1 (assembly) D.O.F.  4
Solver problem. Zero pivot when processing node 1 (assembly) D.O.F.  5
Solver problem. Zero pivot when processing D.O.F. 4 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_4_1_1_1_1.
Solver problem. Zero pivot when processing D.O.F. 5 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_5_1_1_1_1.
The system matrix has 1 negative eigenvalues.
Solver problem. Zero pivot when processing D.O.F. 4 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_4_1_1_2_1.
Solver problem. Zero pivot when processing D.O.F. 5 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_5_1_1_2_1.
Solver problem. Zero pivot when processing D.O.F. 4 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_4_1_1_3_1.
Solver problem. Zero pivot when processing D.O.F. 5 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_5_1_1_3_1.
ABAQUS
全部回答 (3)
用户_56919 2024年11月21日
有人能解决这问题吗,有偿
2024年11月21日
唐生取经 2023年10月6日
1是材料密度设置不对,2是建立的刚性单元有问题,可能是两个刚性单元有共同的次节点
2023年10月6日
评论 2 点赞
南风CAEer 2023年10月6日
没有输入密度,且约束不够
2023年10月6日
相似问题
查看全部
  • 请问一下,下面这些警告信息怎么处理? 2个回答
    请问一下,下面这些警告信息怎么处理?? Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other cons
  • 谁知道abaqus零主轴怎么办,求求各位大神指导 2个回答
    Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_1. Solver problem. Zero pivot when processing D.O.F. 3 of 1 n
  • 为什么降温法模拟钢绞线(桁架单元)后处理云图中会这样? 2个回答
    Solver problem. Zero pivot when processing D.O.F. 2 of 4 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_1_1_1_1. Solver problem. Zero pivot when processing D.O.F. 1 of 6 n
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
Isight_Adams Car联合仿真_suspension案例--excle方式
东邪不邪 东邪不邪
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
