顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
大佬帮忙看看问题出在哪里了,感谢?
浏览: 3219
For two-dimensional models, if a non-unity thickness is specified for two-dimensional solid elements and these elements are involved in an interaction such as contact, the same thickness should be specified for the out-of-plane thickness of the corresponding surface under *surface interaction.
The request for mises output will be replaced by a request for s output
Integration and section point output variables will not be output for deformable elements that are declared as rigid using the *rigid body option
3 nodes associated with rigid bodies have boundary conditions prescribed at nodes other than the reference node. These boundary conditions will be transferred to the associated rigid body reference node.The reference nodes and the dependent nodes have been identified in node set WarnNodeOverconBoundRB.
Nodes belonging to 1 RIGID BODIES have boundary conditions prescribed at nodes other than the reference node. These boundary conditions indicate the rigid bodies cannot rotate about certain axes. Zero rotational boundary conditions have been added to these reference nodes.The reference nodes have been identified in node set WarnNodeOverconBoundRBRot.
343 nodes have dof on which incorrect boundary conditions may have been specified. The nodes have been identified in node set WarnNodeBCIncorrectDof.
DEFORM UT DIC
全部回答 (0)
相似问题
查看全部
  • abaqus monitor的問題,需如何改善? 6个回答
    You have entered a zero or negative density value. Abaqus allows non-physical data; however, most applications expect a positive density value and greater than 1.00000e-36 . 4 nodes associated with ri
  • 【ABAQUS--设置连接器】梁两端设置连接器不收敛? 4个回答
    麻烦大家指导下~~~~ ABAQUS模拟杆件系统中,一个杆两段均设置非线性轴向连接器,一开始就不收敛算不过去。尝试过一端连接器,一段MPC-tie连接可以收敛,希望大神指导下~~ 错误警告: One or more thickness of the box section is greater than 0.1 of the cross section dimension. The torsion
  • 水下井口局部有限元分析模型报错及警告问题求解? 暂无回答
    用ABAQUS进行分析时,总是算了一下就出错,看了一下warning和Error主要是这些问题,求问怎么解决? 1.5624 nodes have dof on which incorrect boundary conditions may have been specified. The nodes have been identified in node set WarnNodeBCIncor
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
step by step 教你如何在abaqus中使用实体单元和连接单元建立螺栓连接
幻想飞翔 幻想飞翔
¥30
陈东陈 陈东陈
免费
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
abaqus埋地管道受力分析
abaqus埋地管道受力分析
冷月 冷月
¥25
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
