错误提示Program aborted with system error 65533什么原因?
ABAQUS/Eplicit 利用VUMAT计算复合材料三点弯,刚开始计算很正常,算到中途出现错误提示:
The executable C:\Program aborted with system error code 65533. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
请问大神们,这可能是什么原因,不胜感激
全部回答 (1)
有可能是质量缩放设置太大了
2018年11月28日
