顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • 制造工艺
ansys一段代码,关于平板焊接的,运行有问题,精通ansys的大神能帮着修改一下吗
浏览: 1670
ET,1,SOLID70
BLOCK,0,0.08,0,0.09,0,0.006
BLOCK,0.08,0.17,0,0.09,0,0.006
BLOCK,0.17,0.19,0,0.09,0,0.006
BLOCK,0.19,0.3,0,0.09,0,0.006
VGLUE,ALL
MPTEMP,1,20,100,300,400,500,700
MPTEMP,7,900,1470,1550,1600,2500,5000
MPDATA,KXX,1,1,52,51,44,43,37,32.5
MPDATA,KXX,1,7,26.2,31.4,120,120,120,120
*DIM,CONV1,TABLE,17,1,1,TEMP
*SET,CONV1(1,0,1),20
*SET,CONV1(1,1,1),2.5
*SET,CONV1(2,0,1),100
*SET,CONV1(2,1,1),5.4
*SET,CONV1(3,0,1),300
*SET,CONV1(3,1,1),7
*SET,CONV1(4,0,1),500
*SET,CONV1(4,1,1),7.7
*SET,CONV1(5,0,1),750
*SET,CONV1(5,1,1),8.2
*SET,CONV1(6,0,1),1000
*SET,CONV1(6,1,1),8.5
*SET,CONV1(7,0,1),1590
*SET,CONV1(7,1,1),9.1
*SET,CONV1(8,0,1),5000
*SET,CONV1(8,1,1),10
LESIZE,57,,,20,3
LESIZE,58,,,20,3
LESIZE,59,,,20,3
LESIZE,60,,,20,3
LESIZE,47,,,4
LESIZE,46,,,4
LESIZE,49,,,20,1/3
LESIZE,50,,,20,1/3
LESIZE,51,,,20,1/3
LESIZE,52,,,20,1/3
LESIZE,53,,,20
LESIZE,54,,,20
LESIZE,55,,,20
LESIZE,56,,,20
Vmesh,all
R=3.25e-3
U=22
I=220
Q0=3*U*I*0.7/(3.14*R**2)
J=0
*DO,I,0,0.09,0.003
J=J+0.25
/solu
ANTYPE,4
TRNOPT,FULL
TUNIF,20
TIME,J
NROPT,FULL,,ON
DELTIME,0.01
AUTOTS,ON
OUTRES,BASIC,LAST
KBC,0
LNSRCH,1
TSRES,ERAES
TIMINT,1,THERM
NSEL,S,EXT
SF,ALL,CONV,%CONV1%,20
ALLSEL,ALL
LOCAL,11,1,0.18,I
NSEL,S,LOC,X,0,0.00325
NSEL,R,LOC,Z,0.006
CSYS,0
ESLN,S,0
*GET,nMAX,ELEM,,NUM,MAX
*GET,nMin,ELEM,,NUM,MIN
*DO,ei, nMAX, nMIN
*IF, ei,EQ,1,THEN
*GET,elx,ELEM,ei,cent, x
*GET,ely,ELEM,ei,cent, y
q1=1*exp((-3)*(elx-0.18)**2)/(3.25e-3**2))*exp((-3)*(ABS(ely-i))**2/(3.25e-3**2)
qm=q0*q1
SFE,ei,6,HFLUX,,qm
*ENDIF
*ENDDO
SOLVE
SFDELE,ALL,HFLUX
SFDELE,ALL,CONV
*ENDDO
全部回答 (0)
相似问题
查看全部
  • ansys焊接热分析直接提示不收敛。大佬看下哪里有错。到底哪里有错啊? 3个回答
    /prep7 /units,si mptemp,1,20,250,500,750,1000,1500 mptemp,7,1700,2500 mpdata,kxx,1,1,50,47,40,27,30,35 mpdata,kxx,1,7,140,142 mpdata,ex,1,1,2.05e+11,1.87e+11,1.50e+11,7.00e+10,2.00e+10,1.90e+10 mpdata
  • 混凝土水化热温度应力求解? 1个回答
    我模拟的温度应力不对,有人可以看看吗。 可以微信红包100,后续还有问题 !-test1 !有重力加速度 !对称 X=0 !长度10/2 !时间7天 !提取温度差,加载到结构模型,求解温度应力,参考温度为0 !48小时拆模 !浇筑温度为20 !有重力 /clear *set, day,7 !计算天数,先调试1天 *set, hour, day*24 !计算小时数 *set, BEG_TEMP, 2
  • 仿真3D打印过程温度变化,但一直出问题,请各位大神帮忙看一下 2个回答
    我这是仿真的3D打印过程温度变化的命令流。我是现将所有单元都杀死,然后一个一个的激活,激活一个单元后,给这个单元加载进行分析,分析完之后将该单元 卸载,然后给下一单元加载再进行分析,一直重复此过程,直到所有单元分析完成。但在生死单元循环中,即*DO循环中。那个RESTART命令提示必须加一 个FINISH命令才能开始RESTART,但是加了之后,仍然不对。请各位帮忙看一下我的命令流哪里有问题,谢谢
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
陈东陈 陈东陈
免费
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
