abaqusSurface from element type c3d10 cannot be used with contact pair in abaqus/explicit Surfac?
Contact pair references surface/node-based surface/analytical rigid surface assembly__pickedsurf2448 but this surface/node-based surface/analytical rigid surface cannot be used with *contact pair. Check previous warning messages for this surface to find the cause.
Analysis Input File Processor exited with an error - Please see the 25-1-12-Job-1.dat file for possible error messages if the file exists.
全部回答 (0)
