ABAQUS提交job时出现的问题? 100
ABAQUS提交job后报错,显示The executable explicit.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
上网也百度过,ABAQUS版本为6.14,说是将mkl_avx2.dll改名为mkl_avx2.14.0.0.1.dll,但是尝试后仍然出现同样的问题,希望能得到指导。
全部回答 (0)
