anasys静力学分析出现上千个警告,求大神? 20
多数是这种,计算时闪退
*** WARNING *** CP = 43.547 TIME= 14:31:10
Specified degree of freedom constraint UZ at unused node 3.
Specified degree of freedom constraint UZ at unused node 5.
Specified degree of freedom constraint UZ at unused node 7.
*** WARNING *** SUPPRESSED MESSAGE CP = 43.547 TIME= 14:31:10
Specified degree of freedom constraint UZ at unused node 9.
Specified degree of freedom constraint UZ at unused node 11.
Specified degree of freedom constraint UZ at unused node 13.
Specified degree of freedom constraint UZ at unused node 15.
Specified degree of freedom constraint UZ at unused node 17.
Specified degree of freedom constraint UZ at unused node 19.
Specified degree of freedom constraint UZ at unused node 21.
Specified degree of freedom constraint UZ at unused node 23.
Specified degree of freedom constraint UZ at unused node 25.
Specified degree of freedom constraint UZ at unused node 27.
Specified degree of freedom constraint UZ at unused node 29.
Specified degree of freedom constraint UZ at unused node 31.
The number of ERROR and WARNING messages exceeds 10000.
Use the /NERR command to increase the number of messages.
The ANSYS run is terminated by this error.
邹正刚 2018年1月23日
