顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
Workbench中错误提示:An error occurred while starting..? 20
浏览: 8467 回答: 4
电脑以前没有被网管监控,因此ANSYS软件均可用,当天晚上因计算需要没有关闭电脑(且workbench也未关闭),当天很多人选择了关机。第二天发现workebnch不能进行运算,但网格划分均可完成,而其他人的ansys完全不能打开。申请软件权限开通以后,且在Workbench中进行任何求解时均会出现错误提示:An error occurred while starting the solver module. Please refer to the Troubleshooting section in the ANSYS Mechanical user guide.参考http://www.eureka.im/5172.html的解决方式,均解决不了,不能求解。workbench错误提示.png
错误提示及解决方法如下:
An error occurred while starting the ANSYS solver module. Please refer to the Troubleshooting section in the ANSYS Workbench Manual
Explanation: This problem occurs when trying to solve an analysis in Workbench that is stored on a network drive using a UNC path. For example: computer_namefoldername. In ANSYS Workbench 12.0 when a solve is started it runs the Ansys120.exe executable. This in turn runs the Windows Cmd.exe interface. The Windows Cmd.exe interface is unable to handle UNC paths which cause this problem.
There are two possible resolutions/workarounds for this issue:
Resolution 1: Map the network drive to a drive letter on the local machine to resolve this issue.
Windows Explorer > Tools menu > Map Network Drive.
Select a drive letter and enter the UNC path to the directory where the analysis is stored, for example: computer_namefoldername
Resolution 2: The following Microsoft Base article is a workaround to allow the Cmd.exe interface to run using UNC paths. <a target=_blank href="http://support.microsoft.com/kb/156276">http://support.microsoft.com/kb/156276</a>http://support.microsoft.com/kb/156276
Resolution 3: This problem can also occur when the ANSYS Mechanical package is not installed on the machine. Check the install directory for a `<install_dir>v120ansys` folder (Example: Crogram FilesANSYS Incv120ansys). If this folder does not exist then the Mechanical package is not installed.
请问如何做才能使软件正常使用?(软件权限均已开通)
ANSYS 结构CAE 机械电子
全部回答 (4)
数理统计 2022年11月18日
2022年11月18日
看惯^一切~ 2020年10月22日
这个问题我已经解决,解决方法是,在mechanical窗口下的tool-solve process settings 里点击advanced 把max number of utilized cores改成1
2020年10月22日
小小木 2020年5月7日
换版本都没有用
2020年5月7日
木昙 2019年7月26日
同求答案
2019年7月26日
相似问题
查看全部
  • error occurred while starting the solver module? 5个回答
    在ansysworkbench中solve的时候总是出现“An error occurred while starting the solver module. Please refer to the Troubleshooting section in the ANSYS Mechanical User Guide.”这个错误的提示,试了好多遍,下了好多次ansys,总是会出现这个?关闭过电脑管
  • Ansys an error occurred while starting the solve module please refer to the troubleshooting section in the ANSYS Mechanical User Guide? 3个回答
    静态分析求解的时候解不出来,总是提示an error occurred while starting the solve module please refer to the troubleshooting section in the ANSYS Mechanical User Guide
  • 关于下面这个帖子中提到的问题,有大佬知道为什么吗? 3个回答
    Xingsheng Sun (Mechanical)(OP)18 Aug 21 21:51 Dear folks, I am trying to use C++ VUMAT in the abaqus on the university supercomputer, but it does not work. I have successfully tested the C++ VUMAT and
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
如何为您的应用选择合适的传声器
如何为您的应用选择合适的传声器
HBK声学与振动 HBK声学与振动
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
Altair FlowSimulator一维流体仿真分析软件介绍&模型搭建案例分享
ALTAIR ALTAIR
免费
教你用10分钟快速完成自行车结构CAE分析!
技术邻直播 技术邻直播
免费
