win8系统,安装了ABAQUS6.14,遇到下列问题,如何破?
job提交成功,但是出现错误代码The executable standard.exe aborted with system error code 1073741795. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
全部回答 (3)
我有个win8下安装abaqus的视频教程
2017年3月21日
评论 2 点赞
百度下,
2017年3月21日
是否之前提交过,请尝试删除 .dat, .msg, and .sta files文件再提交。
2017年3月21日
评论 4 点赞
