急求 急求!!!abaqus子程序关联出错?
各位老师好,小弟目前研究生在读,在应用子程序关联中出错,不知何故,请各位大神指导帮助,万分感谢!
系统win10,abaqus6.14-3,fortran2013,VS2013,在关联中Verify文件显示如下内容(第1段),在调用子程序USDFLD中出现(第2段)显示错误,急求各位老师帮助!谢谢
Abaqus/Standard with user subroutines
...ERROR
Abaqus did not complete successfully.
Please see std_user.log for details.
Continuing...
Abaqus Error: The executable standard.exe
aborted with system error code 1073741819.
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information. Use the same command to run Abaqus that you
used when the problem occurred. Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
Abaqus/Analysis exited with errors
全部回答 (2)
应该是编译器和求解器以及系统之间兼容性出了问题吧
