顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
abaqus隐式分析中contact control设置问题以及后处理中输出的strain energy为负值切较大的问题
浏览: 6880 回答: 4
模拟一层预浸料弯曲变形,使用的是S4单元,
contact control设置如下
仿真完成之后creat xy data
ALLSD和ALLSE
其中ALLSD随着时间步数值如下:
0 0
0.000758867 1.5037E-010
0.0443268 6.14717
0.291301 3475.9
0.344406 8131.14
0.700145 17450.8
1 17845.1
ALLSE随着时间步如下
0 -2.20256E+008
0.000758867 -2.20256E+008
0.0443268 -2.20256E+008
0.291301 -2.20192E+008
0.344406 -2.20143E+008
0.700145 -2.20087E+008
1 -2.20084E+008
而动能ALLKE却一直未零!!
abaqus帮助文档里面的说明如下:
 Although the automatically calculated damping coefficient typically provides enough damping to eliminate the rigid body modes without having a major effect on the solution, there is no guarantee that the value is optimal or even suitable. This is particularly true for thin shell models, in which the damping may be too high. Hence, you may have to increase the damping if the convergence behavior is problematic or decrease the damping if it distorts the solution. The first case is obvious, but the latter case requires a postanalysis check. There are several ways to carry out such checks. The simplest method is to consider the ratio between the energy dissipated by viscous damping and a more general energy measure for the model, such as the elastic strain energy. These quantities can be obtained as output variables ALLSD and ALLSE, respectively. More detailed information can be obtained by comparing the contact damping stresses CDSTRESS (with the individual components CDPRESS, CDSHEAR1, and CDSHEAR2) to the true contact stresses CSTRESS (with the individual components CPRESS, CSHEAR1, and CSHEAR2). If the contact damping stresses are too high, you should decrease the damping. The comparison should be made after contact is firmly established; the contact damping stresses will always be relatively high when contact is not yet or only partially established.
大概意思是设置contact control可以有助于收敛,可是结果需要自己来验证,可以用ALLSD与ALLSE的比值来判断结果的准确性,可是我这个ALLSE是负值,虽然绝对值很大。
使用的s4单元,排除了沙漏能造成能量为负的原因
我的问题是我的结果是否可靠呢?帮助文档里面说的对比ALLSE和ALLSD是用的是绝对值来对比吗?
@邹十平 @fhaih @刘瑾 @ssg @邓晓迪 @tytyy @魏岩 @夏嘉延 @撒打算打算 @yzdsd @noncivilized @李呵呵 @君莫 @changyingluanwu @房博士
ABAQUS CAE 结构CAE
全部回答 (3)
阿瓦隆号 2019年5月29日
我从来没检查过这个能量。这个参数在我看来是为了解决初试接触不良,刚体位移而存在的,接触稳定后就没啥意义了。比的话我印象是ALLSD ALLIE
2019年5月29日
评论 点赞 1
微信公众号:FILWTBY 2016年10月6日
ALLIE也是负值,大小和ALLSE一样
2016年10月6日
评论 点赞 1
7long 2017年2月24日
楼主解决了吗?contact control这个误差的评估您是什么经验?谢谢!
2017年2月24日
相似问题
查看全部
  • LS-DYNA关键字中的CONTROL_ENERGY是用来干嘛的啊? 4个回答
    如题,一直不明白CONTROL_ENERGY的具体作用,只知道是能量控制,但是是怎么控制的呢?哪位大神能帮我解释下?不胜感激
  • 请问接触控制 contact control 里的stabilization的误差怎么评估? 9个回答
    因为接触总不收敛,也没有特别的warning.使用stabilization 的确能促进收敛,但这个带来的误差一般怎么评估呢?比较能量或者应力吗?一般比值在个什么范围比较合理呢?谢谢
  • abaqus接触在初始步(initial)加不上去contact control ,怎能加上? 3个回答
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
B&K声级计全系列介绍及新款解密
B&K声级计全系列介绍及新款解密
HBK声学与振动 HBK声学与振动
免费
