hypermesh求解时出现错误radioss buikdate在线等,求大神解释
*** OptiStruct defaults set from:
install config file: C:\Program Files\Altair\12.0\/hwsolvers/hwsolver.cfg.
NOTE # 9199
MSGLMT=BRIEF is active, following messages will be suppressed:
741 742 1935 1052 1305 1436 1437 1051 1931 1932 2010
Use MSGLMT=STRICT (e.g. in config file) to turn back full printing.
*** INFORMATION # 743
The total number of rigid elements, whose rotational dependent d.o.f.
are removed because there is no need to constrain those d.o.f., is 36
*** ERROR # 173 ***
A dependent d.o.f. defined more than once in rigid element entry.
GRID ID = 248928
component = 1
*** ERROR # 173 ***
GRID ID = 248928
component = 2
*** ERROR # 173 ***
GRID ID = 248928
component = 3
*** ERROR # 173 ***
GRID ID = 248928
component = 4
*** ERROR # 173 ***
GRID ID = 248928
component = 5
*** ERROR # 173 ***
GRID ID = 248928
component = 6
OPTIMIZATION FILE AND PARAMETER INFORMATION :
FEM model file : E:/assemble five 119(5).fem
Output files prefix : E:/assemble five 119(5)
Model read from files:
FINITE ELEMENT MODEL DATA INFORMATION :
Total # of Grids (Structural) : 108699
Total # of Elements : 116522
Total # of Rigid Elements : 2354
Total # of Rigid Element Constraints : 14124
Total # of Degrees of Freedom : 642531
Total # of Non-zero Stiffness Terms : 17583135
Element Type Information
CTETRA Elements : 8545
CPYRA Elements : 1381
CQUAD4 Elements : 105550
CTRIA3 Elements : 1046
Load and Boundary Information
FORCE Sets : 1
SPC Sets : 1
Material and Property Information
PSOLID Cards : 1
PSHELL Cards : 1
MAT1 Cards : 1
***** ERROR ENCOUNTERED BEFORE COMPLETING THE CHECK RUN *****
Current Memory (RAM) : 204 MB
Estimated Minimum Memory (RAM) for the check run : 207 MB
This error occurs in module "prpdrv".
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED 204 MB
MAXIMUM DISK SPACE USED 1 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED Sun May 22 22:45:41 2016
EXECUTION COMPLETED Sun May 22 22:45:44 2016
ELAPSED TIME 00:00:02
CPU TIME 00:00:02
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
There were 6 error messages during input processing.
The first message is repeated below:
*** ERROR # 173 ***
GRID ID = 248928
component = 1
