顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
hypermesh,radioss bulkdate求解时出现错误
浏览: 5373 回答: 6
 *** OptiStruct defaults set from:
   install config file: C:\Program Files\Altair\12.0\/hwsolvers/hwsolver.cfg.
 NOTE # 9199
 MSGLMT=BRIEF is active, following messages will be suppressed:
 741 742 1935 1052 1305 1436 1437 1051 1931 1932 2010
 Use MSGLMT=STRICT (e.g. in config file) to turn back full printing.
 *** INFORMATION #  743
 The total number of rigid elements, whose rotational dependent d.o.f.
 are removed because there is no need to constrain those d.o.f., is        36
 *** ERROR # 173 ***
 A dependent d.o.f. defined more than once in rigid element entry.
    GRID ID =   248928
  component =        1
 *** ERROR # 173 ***
    GRID ID =   248928
  component =        2
 *** ERROR # 173 ***
    GRID ID =   248928
  component =        3
 *** ERROR # 173 ***
    GRID ID =   248928
  component =        4
 *** ERROR # 173 ***
    GRID ID =   248928
  component =        5
 *** ERROR # 173 ***
    GRID ID =   248928
  component =        6
OPTIMIZATION FILE AND PARAMETER INFORMATION :
  FEM model file               : E:/assemble five 119(5).fem
  Output files prefix          : E:/assemble five 119(5)
  Model read from files:
FINITE ELEMENT MODEL DATA INFORMATION :
  Total # of Grids (Structural)        :    108699
  Total # of Elements                  :    116522
  Total # of Rigid Elements            :      2354
  Total # of Rigid Element Constraints :     14124
  Total # of Degrees of Freedom        :    642531
  Total # of Non-zero Stiffness Terms  :  17583135
  Element Type Information
   CTETRA   Elements   :     8545
   CPYRA    Elements   :     1381
   CQUAD4   Elements   :   105550
   CTRIA3   Elements   :     1046
  Load and Boundary Information
   FORCE Sets        :         1
   SPC   Sets        :         1
  Material and Property Information
   PSOLID Cards      :         1
   PSHELL Cards      :         1
   MAT1   Cards      :         1
 ***** ERROR ENCOUNTERED BEFORE COMPLETING THE CHECK RUN *****
 Current Memory (RAM)                                    :     204 MB
 Estimated Minimum Memory (RAM) for the check run        :     207 MB
 This error occurs in module "prpdrv".
RESOURCE USAGE INFORMATION
 MAXIMUM MEMORY USED                                       204 MB
 MAXIMUM DISK SPACE USED                                     1 MB
COMPUTE TIME INFORMATION
 EXECUTION STARTED                         Sun May 22 22:45:41 2016
 EXECUTION COMPLETED                       Sun May 22 22:45:44 2016
 ELAPSED TIME                                         00:00:02
 CPU TIME                                             00:00:02
 *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                        ***** END OF REPORT *****
 For Useful OptiStruct Tips and Tricks, go to the URL:
 http://www.altairhyperworks.com/tips.aspx
 There were 6 error messages during input processing.
  The first message is repeated below:
  *** ERROR # 173 ***
     GRID ID =   248928
   component =        1
Hyperworks.Radioss 显式动力学及仿真 CAE HyperWorks 结构CAE
全部回答 (6)
小豆丁 2018年5月6日
你好,请问最后问题解决了吗?谢谢
2018年5月6日
争朝夕 2017年12月21日
你好,请问你的问题是怎么解决的?
2017年12月21日
张泽工 2017年6月29日
问题多,回答的太少了
2017年6月29日
智创仿真 2016年5月23日
这不是昨天那个问题吗?~~~~~
2016年5月23日
奈more 2016年5月23日
@周游 @智创仿真
2016年5月23日
洪鹄 2016年5月22日
求大神解释
2016年5月22日
相似问题
查看全部
  • hypermesh求解时出现错误radioss buikdate在线等,求大神解释 2个回答
    *** OptiStruct defaults set from: install config file: C:\Program Files\Altair\12.0\/hwsolvers/hwsolver.cfg. NOTE # 9199 MSGLMT=BRIEF is active, following messages will be suppressed: 741 742 1935 105
  • hyperworks 求助 很急 在线等 6个回答
    hyperworks 进行优化分析时出现错误 提示如下: There were 18 error messages during input processing. The first message is repeated below: *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element e
  • optistruct随机震动遇到错误,求大神指点,跪求? 10个回答
    *** ERROR # 23 *** ID 2 used on Case Control data DLOAD is missing in bulk data. *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry .GRID ID =3073590 component=1
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
step by step 教你如何在abaqus中使用实体单元和连接单元建立螺栓连接
幻想飞翔 幻想飞翔
¥30
陈东陈 陈东陈
免费
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
无网格划分软件midas MeshFree - 功能培训
MIDAS官方 MIDAS官方
免费
探究实时仿真GPU求解器加速汽车行业设计创新
Ansys中国 Ansys中国
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
【入门案例02】Abaqus——钢筋混凝土构件的碳纤维布+钢板加固模拟
臻元咨询
¥30
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
精品课程A30-考虑初始缺陷的栓焊连接组合节点滞回模拟
大平-结构工程 大平-结构工程
¥598
vof案例-射流
vof案例-射流
CFD流 CFD流
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
活泼可男_matlab教学 活泼可男_matlab教学
¥10
船舶行进过程中的流场分布规律分析
船舶行进过程中的流场分布规律分析
龙樱 龙樱
免费
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
品索设计-Creo自学练习集讲解(草绘部分)
深圳品索设计Creo培训 深圳品索设计Creo培训
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
