使用壳单元和通用接触出现这个警告直接开始就1U了,不知道是啥原因? 100
The general contact domain for modeling contact interactions in Abaqus/Standard has double-sided facets. Initial contact adjustments for resolving gaps and overclosures when a surface with double-sided facets is paired with any surface having double-sided facets may be incorrect. Similarly, adjustments for double-sided surfaces crossing each other may be incorrect and no additional warnings or error messages will be issued. In all these cases, we recommend using single-sided surfaces under *CONTACT INITIALIZATION ASSIGNMENT to handle initial adjustments more precisely and avoid possible convergence problems.
求大神解答下,万分感谢
全部回答 (2)
壳单元有2个面,接触设置的容差太大了,导致与2个面都接触了
2022年6月9日
模型
2022年6月9日
