ABAQUS模拟? 30
采用ABAQUS做弹塑性膜材的找准静态动力分析,出现如下错误,怎么办 Error in job model33001000suxin: The elements contained in element set ErrElemExcessDistortion-Step2 have distorted excessively. Error in job model33001000suxin: There is only one excessively distorted element Error in job model33001000suxin: The ratio of deformation speed to wave speed exceeds 1.0000 in at least one element. This usually indicates an error with the model definition. Additional diagnostic information may be found in the message file. Error in job model33001000suxin: The elements contained in element set ErrElemExcessDistortion-Step2 have distorted excessively.
全部回答 (1)
訊息顯示有單元變形量過大,你可以到可视化模塊檢查這些單元對應的位置,看一下是否材料或是邊界條件設置不當
2021年4月30日
郑钧 Adam 2021年4月30日
