顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
求助,SLM仿真生死单元问题? 26
浏览: 2190
请问各位大佬,我在模拟两层铺粉的SLM加工过程时,将上层单元杀死后,在计算第一层的过程中上层相邻死单元依旧传热,图中黑线上方为杀死的单元,明显看到发生传热,这是怎么回事 finish /clear /prep7 /unit,si et,1,solid70 !****材料属性设置**** et,1,solid70 mptemp,1,20,200,400,600,800,1000 mptemp,7,1200,1400,1500,1600,1700 mpdata,c,1,1,470,508,550,592,634,676 mpdata,c,1,7,719,900,873,873,873 mpdata,kxx,1,1,13.31,16.33,19.47,22.38,25.07,27.53 mpdata,kxx,1,7,29.76,31.95,63.78,63.78,63.78 mpdata,c,2,1,470,508,550,592,634,676 mpdata,c,2,7,719,765,900,873,873 mpdata,kxx,2,1,0.15,0.23,0.32,0.41,0.50,0.59 mpdata,kxx,2,7,0.68,31.95,63.78,63.78,63.78 !* mptemp mptemp,1,0,500,1000,1500 mpdata,dens,1,1,8000,8000,8000 !* mptemp mptemp,1,20,1380,1381 mpdata,dens,2,1,5013,7833,8000 block,0,0.005,0,0.003,0,0.001 block,0.0019,0.0031,0.0009,0.0021,0.001,0.00103 block,0.0019,0.0031,0.0009,0.0021,0.00103,0.00106 vglue,all K,17,0,0.0009,0, K,18,0.005,0.0009,0, K,19,0.005,0.0009,0.001, K,20,0,0.0009,0.001, K,25,0,0.0021,0, K,26,0.005,0.0021,0, K,27,0.005,0.0021,0.001, K,28,0,0.0021,0.001, K,29,0.0019,0,0, K,30,0.0019,0.003,0, K,31,0.0019,0.003,0.001, K,32,0.0019,0,0.001, K,33,0.0031,0,0, K,34,0.0031,0.003,0, K,35,0.0031,0.003,0.001, K,36,0.0031,0,0.001, A,17,18,19,20 A,25,26,27,28 A,29,30,31,32 A,33,34,35,36 ASEL,S,,,15,16,1 ASEL,A,,,2 ASEL,A,,,13 VSBA,5,ALL ALLSEL,ALL vglue,all lesize,17,0.00002 lesize,20,0.00002 lesize,21,0.000015 lesize,30,0.00002 lesize,29,0.00002 lesize,37,0.000015 type,1 mat,2 vsweep,2 type,1 mat,2 vsweep,4 !***********竖线尺寸************** LESIZE,9, , ,15,2, , , ,1 LESIZE,12, , ,15,2, , , ,1 LESIZE,28, , ,15,2, , , ,1 LESIZE,36, , ,15,2, , , ,1 LESIZE,44, , ,15,2, , , ,1 LESIZE,48, , ,15,2, , , ,1 LESIZE,49, , ,15,2, , , ,1 LESIZE,50, , ,15,2, , , ,1 LESIZE,52, , ,15,2, , , ,1 LESIZE,54, , ,15,2, , , ,1 LESIZE,10, , ,15,0.5, , , ,1 LESIZE,11, , ,15,0.5, , , ,1 LESIZE,26, , ,15,0.5, , , ,1 LESIZE,34, , ,15,0.5, , , ,1 LESIZE,42, , ,15,0.5, , , ,1 LESIZE,46, , ,15,0.5, , , ,1 !*********横线尺寸**************** LESIZE,59, , ,20,0.1, , , ,1 LESIZE,60, , ,20,0.1, , , ,1 LESIZE,62, , ,20,0.1, , , ,1 LESIZE,67, , ,20,0.1, , , ,1 LESIZE,68, , ,20,0.1, , , ,1 LESIZE,70, , ,20,0.1, , , ,1 LESIZE,75, , ,20,0.1, , , ,1 LESIZE,76, , ,20,0.1, , , ,1 LESIZE,78, , ,20,0.1, , , ,1 LESIZE,83, , ,20,0.1, , , ,1 LESIZE,84, , ,20,0.1, , , ,1 LESIZE,86, , ,20,0.1, , , ,1 LESIZE,59, , ,20,0.1, , , ,1 LESIZE,61, , ,20,10, , , ,1 LESIZE,69, , ,20,10, , , ,1 LESIZE,77, , ,20,10, , , ,1 LESIZE,85, , ,20,10, , , ,1 !************中线尺寸************* LESIZE,65, , ,10,0.1, , , ,1 LESIZE,66, , ,10,0.1, , , ,1 LESIZE,72, , ,10,0.1, , , ,1 LESIZE,73, , ,10,0.1, , , ,1 LESIZE,74, , ,10,0.1, , , ,1 LESIZE,80, , ,10,0.1, , , ,1 LESIZE,88, , ,10,0.1, , , ,1 LESIZE,64, , ,10,0.1, , , ,1 LESIZE,82, , ,10,0.1, , , ,1 LESIZE,58, , ,10,0.1, , , ,1 LESIZE,81, , ,10,0.1, , , ,1 LESIZE,57, , ,10,0.1, , , ,1 LESIZE,55, , ,10,10, , , ,1 LESIZE,63, , ,10,10, , , ,1 LESIZE,71, , ,10,10, , , ,1 LESIZE,79, , ,10,10, , , ,1 LESIZE,87, , ,10,10, , , ,1 LESIZE,63, , ,10,10, , , ,1 type,1 mat,1 VSEL,S,,,6,12,1 VSEL,A,,,1 VSEL,A,,,3 vsweep,ALL ALLSEL,ALL !****对流载荷加载(除加工面外其他外表面都选上)******** asel,s,,,9,12,1 asel,a,,,26,28,1 asel,a,,,31,34,1 asel,a,,,37,40,1 asel,a,,,43,46,1 asel,a,,,40 asel,a,,,49,62,1 SFA,all,,CONV,480,22 ALLSEL,ALL !**************************** TUNIF,22 !预热温度 FINISH /SOL !****激光参数设置**** P=275 !功率 w0=0.05e-3 !光斑半径 v=0.8 !激光扫描速度 d=0.06e-3 !激光扫描间距 f=0.07 pi=3.1415926 a=0.05E-3 b=0.05E-3 c=5 !********************** ! ****瞬态求解参数设置**** lstep=0.08e-3 !扫描步长为0.1mm time_step=lstep/v !载荷步时间大小 ANTYPE,4 !定义新分析 TRNOPT,FULL NROPT,FULL TOFFST,273, !定义摄氏度的温度偏移量 LNSRCH,1 TIMINT,1 !打开时间积分选项进行瞬态分析 TINTP,0.005, , ,1, , , !************************ OUTRES,ALL,ALL my_time=0 XX=1.9e-3 !XX,YY用于定义局部坐标的原点 YY=1.32e-3 ZZ=1.03e-3 LOCAL,11,0,XX,YY,ZZ !**********热源方程设置********** *DEL,_FNCNAME *DEL,_FNCMTID *DEL,_FNC_C1 *DEL,_FNC_C2 *DEL,_FNC_C3 *DEL,_FNC_C4 *DEL,_FNCCSYS *SET,_FNCNAME,'hflux' *DIM,_FNC_C1,,3 *DIM,_FNC_C2,,3 *DIM,_FNC_C3,,3 *DIM,_FNC_C4,,3 *SET,_FNC_C1(2),f *SET,_FNC_C2(2),p *SET,_FNC_C3(2),pi *SET,_FNC_C4(2),w0 *SET,_FNC_C1(3),f *SET,_FNC_C2(3),p *SET,_FNC_C3(3),pi *SET,_FNC_C4(3),w0 *SET,_FNCCSYS,11 ! /INPUT,hflux.func,,,1 *DIM,%_FNCNAME%,TABLE,6,31,3,,,,%_FNCCSYS% ! ! Begin of equation: {z} *SET,%_FNCNAME%(0,0,1), 0.001, -999 *SET,%_FNCNAME%(2,0,1), 0.0 *SET,%_FNCNAME%(3,0,1), 0.0 *SET,%_FNCNAME%(4,0,1), 0.0 *SET,%_FNCNAME%(5,0,1), 0.0 *SET,%_FNCNAME%(6,0,1), 0.0 *SET,%_FNCNAME%(0,1,1), 1.0, 99, 0, 1, 4, 0, 0 *SET,%_FNCNAME%(0,2,1), 0 *SET,%_FNCNAME%(0,3,1), 0 *SET,%_FNCNAME%(0,4,1), 0 *SET,%_FNCNAME%(0,5,1), 0 *SET,%_FNCNAME%(0,6,1), 0 *SET,%_FNCNAME%(0,7,1), 0 *SET,%_FNCNAME%(0,8,1), 0 *SET,%_FNCNAME%(0,9,1), 0 *SET,%_FNCNAME%(0,10,1), 0 *SET,%_FNCNAME%(0,11,1), 0 *SET,%_FNCNAME%(0,12,1), 0 *SET,%_FNCNAME%(0,13,1), 0 *SET,%_FNCNAME%(0,14,1), 0 *SET,%_FNCNAME%(0,15,1), 0 *SET,%_FNCNAME%(0,16,1), 0 *SET,%_FNCNAME%(0,17,1), 0 *SET,%_FNCNAME%(0,18,1), 0 *SET,%_FNCNAME%(0,19,1), 0 *SET,%_FNCNAME%(0,20,1), 0 *SET,%_FNCNAME%(0,21,1), 0 *SET,%_FNCNAME%(0,22,1), 0 *SET,%_FNCNAME%(0,23,1), 0 *SET,%_FNCNAME%(0,24,1), 0 *SET,%_FNCNAME%(0,25,1), 0 *SET,%_FNCNAME%(0,26,1), 0 *SET,%_FNCNAME%(0,27,1), 0 *SET,%_FNCNAME%(0,28,1), 0 *SET,%_FNCNAME%(0,29,1), 0 *SET,%_FNCNAME%(0,30,1), 0 *SET,%_FNCNAME%(0,31,1), 0 ! End of equation: {z} ! ! Begin of equation: (f*p/(pi*w0^2))*exp(-({x}^2+{y}^2)/w0^2) *SET,%_FNCNAME%(0,0,2), 0.0010001, -999 *SET,%_FNCNAME%(2,0,2), 0.0 *SET,%_FNCNAME%(3,0,2), %_FNC_C1(2)% *SET,%_FNCNAME%(4,0,2), %_FNC_C2(2)% *SET,%_FNCNAME%(5,0,2), %_FNC_C3(2)% *SET,%_FNCNAME%(6,0,2), %_FNC_C4(2)% *SET,%_FNCNAME%(0,1,2), 1.0, -1, 0, 1, 17, 3, 18 *SET,%_FNCNAME%(0,2,2), 0.0, -2, 0, 2, 0, 0, 20 *SET,%_FNCNAME%(0,3,2), 0, -3, 0, 1, 20, 17, -2 *SET,%_FNCNAME%(0,4,2), 0.0, -2, 0, 1, 19, 3, -3 *SET,%_FNCNAME%(0,5,2), 0.0, -3, 0, 1, -1, 4, -2 *SET,%_FNCNAME%(0,6,2), 0.0, -1, 0, 0, 0, 0, 0 *SET,%_FNCNAME%(0,7,2), 0.0, -2, 0, 1, 0, 0, -1 *SET,%_FNCNAME%(0,8,2), 0.0, -4, 0, 1, -1, 2, -2 *SET,%_FNCNAME%(0,9,2), 0.0, -1, 0, 2, 0, 0, 2 *SET,%_FNCNAME%(0,10,2), 0.0, -2, 0, 1, 2, 17, -1 *SET,%_FNCNAME%(0,11,2), 0.0, -1, 0, 2, 0, 0, 3 *SET,%_FNCNAME%(0,12,2), 0.0, -5, 0, 1, 3, 17, -1 *SET,%_FNCNAME%(0,13,2), 0.0, -1, 0, 1, -2, 1, -5 *SET,%_FNCNAME%(0,14,2), 0.0, -2, 0, 1, -4, 3, -1 *SET,%_FNCNAME%(0,15,2), 0.0, -1, 0, 2, 0, 0, 20 *SET,%_FNCNAME%(0,16,2), 0.0, -4, 0, 1, 20, 17, -1 *SET,%_FNCNAME%(0,17,2), 0.0, -1, 0, 1, -2, 4, -4 *SET,%_FNCNAME%(0,18,2), 0.0, -1, 7, 1, -1, 0, 0 *SET,%_FNCNAME%(0,19,2), 0.0, -2, 0, 1, -3, 3, -1 *SET,%_FNCNAME%(0,20,2), 0.0, 99, 0, 1, -2, 0, 0 *SET,%_FNCNAME%(0,21,2), 0 *SET,%_FNCNAME%(0,22,2), 0 *SET,%_FNCNAME%(0,23,2), 0 *SET,%_FNCNAME%(0,24,2), 0 *SET,%_FNCNAME%(0,25,2), 0 *SET,%_FNCNAME%(0,26,2), 0 *SET,%_FNCNAME%(0,27,2), 0 *SET,%_FNCNAME%(0,28,2), 0 *SET,%_FNCNAME%(0,29,2), 0 *SET,%_FNCNAME%(0,30,2), 0 *SET,%_FNCNAME%(0,31,2), 0 ! End of equation: (f*p/(pi*w0^2))*exp(-({x}^2+{y}^2)/w0^2) ! ! Begin of equation: (f*p/(0.00003*pi*w0^2))*exp(-({x}^2+{y}^2)/w0^2)*exp(-abs ! ({z})/0.00003) *SET,%_FNCNAME%(0,0,3), 0.00103, -999 *SET,%_FNCNAME%(2,0,3), 0.0 *SET,%_FNCNAME%(3,0,3), %_FNC_C1(3)% *SET,%_FNCNAME%(4,0,3), %_FNC_C2(3)% *SET,%_FNCNAME%(5,0,3), %_FNC_C3(3)% *SET,%_FNCNAME%(6,0,3), %_FNC_C4(3)% *SET,%_FNCNAME%(0,1,3), 1.0, -1, 0, 1, 17, 3, 18 *SET,%_FNCNAME%(0,2,3), 0.0, -2, 0, 0.00003, 0, 0, 19 *SET,%_FNCNAME%(0,3,3), 0, -3, 0, 1, -2, 3, 19 *SET,%_FNCNAME%(0,4,3), 0.0, -2, 0, 2, 0, 0, 20 *SET,%_FNCNAME%(0,5,3), 0.0, -4, 0, 1, 20, 17, -2 *SET,%_FNCNAME%(0,6,3), 0.0, -2, 0, 1, -3, 3, -4 *SET,%_FNCNAME%(0,7,3), 0.0, -3, 0, 1, -1, 4, -2 *SET,%_FNCNAME%(0,8,3), 0.0, -1, 0, 0, 0, 0, 0 *SET,%_FNCNAME%(0,9,3), 0.0, -2, 0, 1, 0, 0, -1 *SET,%_FNCNAME%(0,10,3), 0.0, -4, 0, 1, -1, 2, -2 *SET,%_FNCNAME%(0,11,3), 0.0, -1, 0, 2, 0, 0, 2 *SET,%_FNCNAME%(0,12,3), 0.0, -2, 0, 1, 2, 17, -1 *SET,%_FNCNAME%(0,13,3), 0.0, -1, 0, 2, 0, 0, 3 *SET,%_FNCNAME%(0,14,3), 0.0, -5, 0, 1, 3, 17, -1 *SET,%_FNCNAME%(0,15,3), 0.0, -1, 0, 1, -2, 1, -5 *SET,%_FNCNAME%(0,16,3), 0.0, -2, 0, 1, -4, 3, -1 *SET,%_FNCNAME%(0,17,3), 0.0, -1, 0, 2, 0, 0, 20 *SET,%_FNCNAME%(0,18,3), 0.0, -4, 0, 1, 20, 17, -1 *SET,%_FNCNAME%(0,19,3), 0.0, -1, 0, 1, -2, 4, -4 *SET,%_FNCNAME%(0,20,3), 0.0, -1, 7, 1, -1, 0, 0 *SET,%_FNCNAME%(0,21,3), 0.0, -2, 0, 1, -3, 3, -1 *SET,%_FNCNAME%(0,22,3), 0.0, -1, 0, 0, 0, 0, 0 *SET,%_FNCNAME%(0,23,3), 0.0, -3, 0, 1, 0, 0, -1 *SET,%_FNCNAME%(0,24,3), 0.0, -4, 0, 1, -1, 2, -3 *SET,%_FNCNAME%(0,25,3), 0.0, -1, 15, 1, 4, 0, 0 *SET,%_FNCNAME%(0,26,3), 0.0, -3, 0, 1, -4, 3, -1 *SET,%_FNCNAME%(0,27,3), 0.0, -1, 0, 0.00003, 0, 0, -3 *SET,%_FNCNAME%(0,28,3), 0.0, -4, 0, 1, -3, 4, -1 *SET,%_FNCNAME%(0,29,3), 0.0, -1, 7, 1, -4, 0, 0 *SET,%_FNCNAME%(0,30,3), 0.0, -3, 0, 1, -2, 3, -1 *SET,%_FNCNAME%(0,31,3), 0.0, 99, 0, 1, -3, 0, 0 ! End of equation: (f*p/(0.00003*pi*w0^2))*exp(-({x}^2+{y}^2)/w0^2)*exp(-abs ! ({z})/0.00003) !--> !*******************第一层**************************** Vsel,s,,,4 Eslv,s Ekill,all allsel,all !*******************第一道****************************** *DO,i,0,2,1 LOCAL,11,0,XX,YY,ZZ !****每个载荷步的求解参数设置**** my_time=my_time+time_step TIME,my_time AUTOTS,1 DELTIM,lstep/v,lstep/v,lstep/v, KBC,1 !******************************** !****加载**** NSEL,S,LOC,X,0.0019-XX,0.0031-XX NSEL,R,LOC,Y,0.0009-YY,0.0021-YY NSEL,R,LOC,Z,-0.00004,0 ESLN,S SFE,ALL,1,HFLUX,,%hflux% ALLSEL,ALL ESEL,S,LIVE !************* !****求解,完成后删除载荷**** !save SOLVE SFEDELE,ALL,,HFLUX !****修改超过熔点的单元的材料模型**** ESEL,S,LIVE ESEL,R,MAT,,2 NSLE,S *GET,SELNNUM,NODE,,COUNT *get,SLNMIN,node,,num,min *dim,node_temp1,,selnnum *dim,SELNODE1,,SELNNUM SELNODE1(1)=SLNMIN *do,x,2,SELNNUM,1 SELNODE1(x)=ndnext(SELNODE1(x-1)) *enddo *do,f,1,selnnum,1 *get,node_temp1(f),node,selnode1(f),temp *enddo *do,f,1,selnnum,1 *IF,NODE_TEMP1(F),GE,1381,THEN NSEL,S,NODE,,SELNODE1(F) ESLN,S MPCHG,1,ALL *ENDIF *ENDDO ALLSEL,ALL !**************************** XX=XX+lstep *ENDDO
问题图片1
ANSYS ANSYS APDL SLM激光成形 工艺成型及仿真
全部回答 (0)
相似问题
查看全部
  • ansys模拟双椭球热源加载温度过高的问题? 6个回答
    请教大佬们,我是做SLM仿真的,我利用下面的命令流计算得到的温度场温度很高,系统直接提示超过阀值无法运算,不知道到底是哪里的原因,附上命令流求大佬们指导一下 finish /clear /prep7 /unit,si et,1,solid70 !****材料属性设置**** et,1,solid70 mptemp,1,20,200,400,600,800,1000 mptemp,7,1200,14
  • 关于ansys模拟增材制造的问题? 3个回答
    请教大佬们,我是做SLM仿真的,在模拟过程中我发现我得到的温度场始终是这样的圆形,而不是文献中这种类似慧星状的结果,是不是因为在循环加载过程中前一步计算的温度场结果没有被后一步继承,应该怎么解决,附上命令流求大佬们指导一下 finish /clear /prep7 /unit,si et,1,solid70 !****材料属性设置**** et,1,solid70 mptemp,1,20,200,
  • ansys焊接热分析直接提示不收敛。大佬看下哪里有错。到底哪里有错啊? 3个回答
    /prep7 /units,si mptemp,1,20,250,500,750,1000,1500 mptemp,7,1700,2500 mpdata,kxx,1,1,50,47,40,27,30,35 mpdata,kxx,1,7,140,142 mpdata,ex,1,1,2.05e+11,1.87e+11,1.50e+11,7.00e+10,2.00e+10,1.90e+10 mpdata
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
B&K声级计全系列介绍及新款解密
B&K声级计全系列介绍及新款解密
HBK声学与振动 HBK声学与振动
免费
