Unknown global id: 50497 in instance: SOIL-1怎么回事? 20
The executable pre.exe aborted with system error code 529697949. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
这个是在初始地应力提取ODB的时候遇到的,哪位大神知道怎么回事吗
全部回答 (1)
在命令行中,输入 mdb.models['Model-1'].setValues(noPartsInputFile=ON) 关键步骤做了吗?
在excel中数据处理那块是不是按照教程做的呢?望检查
