顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
与umat相关的abaqus错误? 20
浏览: 3006 回答: 3
使用abaqus关联umat做了一个简单的压缩实验,提交作业的时候第一次直接报错
Abaqus Error: Abaqus/Standard Analysis exited with an error - Please see the message file for possible error messages if the file exists.
重新命名作业重新提交作业,显示运行成功,但是没有分析结果
对比两个作业的log文件发现,报错的的作业那里多了如下的提示
forrtl: severe (24): end-of-file during read, unit 83, file e:\Myworks\temp1\texture.txti
Image              PC                Routine            Line        Source
libifcoremd.dll    0000000003E327EF  Unknown               Unknown  Unknown
libifcoremd.dll    0000000003E2C5A3  Unknown               Unknown  Unknown
libifcoremd.dll    0000000003E159AF  Unknown               Unknown  Unknown
libifcoremd.dll    0000000003D783E8  Unknown               Unknown  Unknown
libifcoremd.dll    0000000003D77022  Unknown               Unknown  Unknown
libifcoremd.dll    0000000003DBDAD1  Unknown               Unknown  Unknown
standardU.dll      00007FFB640B5C0D  Unknown               Unknown  Unknown
standardU.dll      00007FFB640E9A6C  Unknown               Unknown  Unknown
standardU.dll      00007FFB6408162A  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BD4A558  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5C4D5CB9  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5B81B85A  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF712BF  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF8EE45  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF83C3C  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF7FBC5  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF67C2F  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5BF66203  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5CCE7EC1  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5B731299  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB5C6076D3  Unknown               Unknown  Unknown
standard.exe       00007FF7909C38E9  Unknown               Unknown  Unknown
standard.exe       00007FF7909C154F  Unknown               Unknown  Unknown
standard.exe       00007FF7909D5F1A  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FFB9A812D92  Unknown               Unknown  Unknown
ntdll.dll          00007FFB9D0A9F64  Unknown               Unknown  Unknown
求解答,在线等
ABAQUS ABAQUS二次开发 UMAT
全部回答 (2)
传播正能量 2019年3月24日
再次查看没有输出结果但运行成功的log文件发现提示了一个错误 ***ERROR Message: nstatv .ne. numgrn*varsPerGrn。然后我再检查umat文件查找了这个提示
2019年3月24日
寒江雪_123 2019年3月24日
这是读取文件时遇到了文件的结束。例如,代码要求数据有3行数据,而实际输入文件只有2行。在某些时候,甚至输入文件根本不存在或是空白文件。此外,数据文件缺失某些行某些列也是较大的可能。当然,也可能是循环读取文件时没控制住。比如想读100行,结果写错了,读了1000行。有时候,可能是文件路径错误,导致实际读取了另一个空白的文件。或者文件扩展名被隐藏了,比如读取 a.txt,但实际的文件名却是 a.txt.txt
2019年3月24日
相似问题
查看全部
  • 使用fric子程序,出现以下错误,怎样解决? 暂无回答
    使用cmd进行提交,错误信息为 Run standard.exe forrtl: severe (24): end-of-file during read, unit 23, file E:\FEA-20220705\Job-2-combination-open-userfric.023 Image PC Routine Line Source libifcoremd.dll 00007FFBB2
  • Abaqus提交umat子程序运行之后报错怎么改正? 9个回答
    编写了各向异性弹性子程序含有27个材料参数,37个状态变量,程序可以running,但是报错,下面是log文件的提示,想咨询这是哪里出的问题? Analysis initiated from SIMULIA established products Abaqus JOB Job-gexiangyixing2 Abaqus 2020 Abaqus License Manager checked ou
  • 使用umat子程序运行了10分之一后出现报错,log文件显示是这样的,请问这该怎么解决呀? 暂无回答
    Analysis initiated from SIMULIA established products Abaqus JOB OHTIM7-Mesh2 Abaqus 2022 Abaqus License Manager checked out the following licenses: Abaqus/Standard checked out 5 tokens from Flexnet se
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
Isight_Adams Car联合仿真_suspension案例--excle方式
东邪不邪 东邪不邪
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
