关于hypermesh求解出现的错误提示?
hypermesh出现的错误提示如下,请教各位大神,该怎么改 Preserving existing .out file as: D:/lingzhizhongmen/zongcheng/zongcheng10_001.out Preserving existing .stat file as: D:/lingzhizhongmen/zongcheng/zongcheng10_001.stat ************************************************************************ ** ** ** ** ** OptiStruct 14.0 ** ** ** ** Design and Optimization Software ** ** from Altair Engineering, Inc. ** ** ** ** ** ** Windows 7 Workstation SP1 (Build 7601) ZHGY-021586 ** ** 12 CPU: Intel(R) Xeon(R) CPU E5-2620 v3 @ 2.40GHz ** ** CPU speed 2400 MHz ** ** 11336 MB RAM, 32580 MB swap ** ** ** ** Build tag: 0801293aw733140_Ce64RBW8UH12M:111035-000 4000000004000 ** ************************************************************************ ** COPYRIGHT (C) 1996-2015 Altair Engineering, Inc. ** ** All Rights Reserved. Copyright notice does not imply publication. ** ** Contains trade secrets of Altair Engineering, Inc. ** ** Decompilation or disassembly of this software strictly prohibited. ** ************************************************************************ *** ERROR # 1000 *** in the input data: Incorrect data in field # 3. ************************************************************************ There were 44 error messages during input processing. The first message is repeated below: *** See next message about line 787968 from file: D:/lingzhizhongmen/zongc
全部回答 (2)
看看网格划分,
2018年10月26日
k文件格式错误,查看你的message文件,里面会有所以error的提示信息,查看哪些行出现了格式错误,k文件格式一般右对齐(跟没错误的行对比即可)。出现格式错误主要是与其他软件不兼容导致的,修改一下即可。
