ABAQUS的vusdfld模拟组织遇到云图显示错误和黑色区域的问题?
在这里附上子程序的内容,麻烦相关人士指正错误:
subroutine vusdfld(
c Read only -
* nblock, nstatev, nfieldv, nprops, ndir, nshr,
* jElemUid, kIntPt, kLayer, kSecPt,
* stepTime, totalTime, dt, cmname,
* coordMp, direct, T, charLength, props,
* stateOld,
c Write only -
* stateNew, field )
c
include 'vaba_param.inc'
c
dimension props(nprops),
* jElemUid(nblock), coordMp(nblock, *),
* direct(nblock, 3, 3), T(nblock,3,3),
* charLength(nblock),
* stateOld(nblock, nstatev),
* stateNew(nblock, nstatev),
* field(nblock, nfieldv)
character*80 cmname
parameter( nrData=6 )
character*3 cData(maxblk*6)
dimension jData(maxblk*nrData)
dimension temp(maxblk*6), eqps(maxblk*6)
jStatus = 1
call vgetvrm( 'TEMP', temp, jData, cData, jStatus )
jStatus = 1
call vgetvrm( 'PEEQ', eqps, jData, cData, jStatus )
do k = 1, nblock
if ( stepTime .eq. 0 ) then
stateOld(k,1) = 0
stateOld(k,2) = 0
stateOld(k,3) = 0
stateOld(k,4) = 0
stateOld(k,5) = 20
stateOld(k,6) = 0
end if
Te = temp(k)
stateNew(k,1) = Te
str = eqps(k)
stateNew(k,2) = str
str1 = stateOld(k,2)
strra = (str-str1)/dt
stateNew(k,3) = strra
zpara = strra*exp(300/(Te+273))
stateNew(k,6) = zpara
! end if
eqc= 0.00158*zpara**0.10662
eq05=0.018063*zpara**0.08518
dfull=1.27e6*zpara**(-0.351)
if (str.ge. eqc) then
de= (str-eqc)/(eq05-eqc)
Xdrx=1-exp(-0.693*(de)**1.92)
if (Xdrx .ge. 0.95) then
stateNew(k,4) = 1
stateNew(k,5) = dfull
else
stateNew(k,4) = Xdrx
stateNew(k,5) = dfull*Xdrx+(1-Xdrx)*20
endif
end if
end do
return
end
全部回答 (2)
我遇到了同样的问题
我也遇到了同样的问题,但是数值结果上看是没问题的
