ABAQUS子程序验证不通过,如何解决? 40
子程序验证报告如下:
Abaqus Product Install Verification...
Thu Jun 15 18:18:20 2017
Running system requirement checks.
Requirement: Windows Server 2003, Windows Server 2008, Windows Server
2008 R2, Windows HPC Server 2008, Windows XP, Windows Vista,
or Windows 7
Product: All Abaqus Products
Status: Pass - Found Windows 7 Professional Service Pack 1 (Build
7601) (x64).
Requirement: Microsoft Visual C++ 9.0 (2008), or 10.0 (2010)
Product: Abaqus make utility with C++
Status: Fail - Unable to locate or determine the version of a C++
compiler on this system. If Microsoft Visual C++ 8.0 (.NET
2005) is installed on this system, please load
vcvarsamd64.bat file before running Abaqus.
Requirement: Intel Fortran Compiler 10.1, or 11.1
Product: Abaqus make utility with Fortran and Abaqus with user
subroutines
Fortran compiler on this system. If Intel Fortran is
installed on this system, please load ifortvars.bat before
running Abaqus.
Requirement: MS-MPI 2.0, 3.0 or greater
Product: Abaqus analyses using MPI-based parallelization and
Abaqus/CFD
Status: Pass - Found MS-MPI 2.1.1765.0.
Requirement: Internet Explorer 6.0 or 7.0 or 8.0, Firefox 2.0 or 3.0 or
3.5 or greater
Product: Abaqus Documentation
Status: Pass - Found Internet Explorer 10.0.9200.17457
Found D:\Temp\verify. All verification files will reside in this directory.
Old job files exist. They will be moved to verifyOLD.
Abaqus/Standard
...PASS
Continuing...
Abaqus/Standard with user subroutines
...INFORMATION
System requirements were not met. Verification
procedure will be skipped. However, user subroutines
can be run using a precompiled library set by the
variable usub_lib_dir. For more information please
see the section 3.2.2 of Abaqus Analysis User's
Manual.
Continuing...
Abaqus/Explicit (single precision)
...PASS
Continuing...
Abaqus/Explicit (double precision)
...PASS
Continuing...
Abaqus/Explicit with user subroutines (single precision)
...INFORMATION
Manual.
Continuing...
Abaqus/Explicit with user subroutines (double precision)
...INFORMATION
Manual.
Continuing...
Abaqus/Viewer
...PASS
Continuing...
Abaqus/CAE
...PASS
Continuing...
Geometry Translator for CATIA V4
...PASS
Continuing...
Geometry Translator for CATIA V5
...PASS
Continuing...
Direct Geometry Import for CATIA V5
...ERROR
Geometry translation failed. Please see
DirectCATIAv5.rpy for details.
Continuing...
Geometry Translator for I-DEAS
...PASS
Continuing...
Geometry Translator for Parasolid
...PASS
Continuing...
Geometry Translator for Pro/ENGINEER
...PASS
Continuing...
SolidWorks Associative Interface
...PASS
Continuing...
Abaqus/AMS
...PASS
Continuing...
Abaqus Interface for MSC.ADAMS
...PASS
Continuing...
Abaqus/Standard parametric studies
...PASS
Continuing...
Abaqus/Explicit parametric studies
...PASS
Continuing...
Abaqus/Design
...PASS
Continuing...
Abaqus Interface for Moldflow
...PASS
Continuing...
...INFORMATION
Continuing...
...INFORMATION
Continuing...
Abaqus make utility with object code
...INFORMATION
Continuing...
Abaqus scripting interface
...PASS
Continuing...
Abaqus analyses using parallelization
Running thread-based parallel with 2 cpu(s)
Abaqus/Explicit domain-level parallel
...PASS
Abaqus/Standard direct solver
...PASS
Continuing...
Abaqus/Foundation
...PASS
Continuing...
Abaqus noGUI (CAE/Viewer)
...PASS
Continuing...
Abaqus/CFD
...PASS
Continuing...
Clean-up...
Job files exist. Verification directory D:\Temp\verify will not be deleted.
烦请大神指导
全部回答 (3)
Abaqus6.14安装教程以及如何关联子程序
http://www.jishulink.com/college/video/c10796?SUID=ccb184b5-1840-4238-bda7-092a1ff61ca2
如果是6.14可以看一下这个
易炜 2017年6月16日
