顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
ANSYS接触滑移分析遇到该错误,求大神指点?
浏览: 2561 回答: 1
鄙人是菜鸡,用的命令流和GUI交互操作,具体操作指令来自.log文件,请大神见谅,
出现错误如下:
 The L-2 norm of the residual force overflowed.  This may be caused by
 PRED,ON or birth/dead elements.  Please use PRED,OFF and try again.
.log中的具体命令为
/PREP7
ET,1,SHELL181
KEYOPT,1,1,0
KEYOPT,1,3,0
KEYOPT,1,8,1
KEYOPT,1,9,0
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,167000000000
MPDATA,PRXY,1,,0.28
MPTEMP,,,,,,,,
MPTEMP,1,0
UIMP,1,REFT,,,
MPDATA,ALPX,1,,3.29e-6
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,2,,60000000000
MPDATA,PRXY,2,,0.17
MPTEMP,,,,,,,,
MPTEMP,1,0
UIMP,2,REFT,,,
MPDATA,ALPX,2,,0.55e-6
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,3,,2.84e10
MPDATA,PRXY,3,,0.24
MPTEMP,,,,,,,,
MPTEMP,1,0
UIMP,3,REFT,,,
MPDATA,ALPX,3,,4.8e-6
tb,czm,4,1,,bili
tbdata,1,1e10,1e-9,3e8,5e-4,1,1
sect,1,shell,,
secdata, 675e-6,1,0.0,3
secoffset,TOP
seccontrol,,,, , , ,
sect,2,shell,,
secdata, 1.5e-007,2,0,3
secdata, 5e-007,1,0,3
secdata, 1e-006,3,0,3
secoffset,BOT
seccontrol,0,0,0, 0, 1, 1, 1
PCIRC,0.0762, ,0,90,
sect,2,shell,,
secoffset,BOT
CM,_Y,AREA
ASEL, , , ,       1
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT,       1, ,   1,       0,   1
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , ,       2
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT,       1, ,   1,       0,   2
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
LESIZE,ALL, , ,20, ,1, , ,1,
MSHAPE,0,2D
MSHKEY,1
FLST,5,2,5,ORDE,2
FITEM,5,1
FITEM,5,-2
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/UI,MESH,OFF
SAVE
/COM, CONTACT PAIR CREATION - START
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
/GSAV,cwz,gsav,,temp
inistate,set,mat,3
inistate,defi,,,,,1e9,1e9
MP,MU,1,
MAT,4
R,3
REAL,3
ET,2,170
ET,3,174
KEYOPT,3,9,0
KEYOPT,3,10,2
R,3,
RMORE,
RMORE,,0
RMORE,0
! Generate the target surface
ASEL,S,,,1
CM,_TARGET,AREA
TYPE,2
NSLA,S,1
ESLN,S,0
ESLL,U
ESEL,U,ENAME,,188,189
NSLE,A,CT2
ESURF
CMSEL,S,_ELEMCM
! Generate the contact surface
ASEL,S,,,2
CM,_CONTACT,AREA
TYPE,3
NSLA,S,1
ESLN,S,0
NSLE,A,CT2 ! CZMESH patch (fsk qt-40109 8/2008)
ESURF
*SET,_REALID,3
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
! Reverse target normals
ESEL,NONE
ESEL,A,TYPE,,2
ESEL,R,REAL,,3
ESURF,,REVERSE
ESEL,ALL
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
/COM, CONTACT PAIR CREATION - END
/MREP,EPLOT
KEYOPT,3,1,0
KEYOPT,3,2,0
KEYOPT,3,4,0
KEYOPT,3,5,2
KEYOPT,3,6,0
KEYOPT,3,7,1
KEYOPT,3,8,0
KEYOPT,3,9,0
KEYOPT,3,10,0
KEYOPT,3,11,1
KEYOPT,3,12,2
KEYOPT,3,14,0
KEYOPT,3,15,0
KEYOPT,3,16,0
R,3,0,0,1, 0.001,0,0
RMORE,0,0,0, 0,0,0
RMORE,0,,, ,,
RMORE,,,0, 0,,
RMORE,,,,,,
RMORE,,,,,
FLST,2,4,4,ORDE,4
FITEM,2,2
FITEM,2,-3
FITEM,2,5
FITEM,2,-6
DL,P51X, ,SYMM
FLST,2,2,1,ORDE,2
FITEM,2,22
FITEM,2,353
/GO
D,P51X, , , , , ,ALL, , , , ,
FINISH
/SOL
SAVE
ALLSEL,ALL
NLGEOM,1
NROPT,FULL, ,
STAOPT,DEFA
LUMPM,0
EQSLV, , ,0, ,DELE
MSAVE,0
PCGOPT,0, ,AUTO, , ,AUTO
PIVCHECK,0
PSTRESS,0
TOFFST,0,
TIME,0.1
AUTOTS,1
NSUBST,100,1e6,10,1
KBC,0
TSRES,ERASE
NLGEOM,1
NROPT,FULL, ,OFF
STAOPT,DEFA
LUMPM,0
EQSLV, , ,0, ,DELE
MSAVE,0
PIVCHECK,1
PSTRESS,0
TOFFST,0,
NEQIT,25,
PRED,OFF
LNSRCH,1
SAVE
求各位大神指点错误出现原因
ANSYS 结构CAE 流体力学及仿真 电磁设计及仿真 工程热物理及仿真 多物理场耦合仿真 有限元理论及编程 汽车工程 机械电子 航空航天 国防军工 土木工程 材料工程 能源化工 船舶海工 生物医学
全部回答 (1)
技术工 2017年3月7日
@ANSYS专家 @张小@水哥ANSYS
2017年3月7日
相似问题
查看全部
  • 有人帮看一下为什么我的分析文件做不了优化不 1个回答
    *SET,L1,200 *SET,L2,40 *SET,H1,10 *SET,H2,10 *SET,H3,30 *SET,B1,20 *SET,B2,80 *SET,R1,20 *SET,R2,6 *SET,R3,15 /PREP7 ET,1,SOLID187 MPTEMP,,,,,,,, MPTEMP,1,0 MPDATA,EX,1,,2.06E5 MPDATA,PRXY,1,,0.3 CYL4
  • 有没有大佬帮忙看看这个程序怎么修改,施加载荷的时候位移载荷不会出错,但是压力载荷却总是出错了? 暂无回答
    FINISH /CLEAR /PREP7 !进入前处理器 ET, 1, PLANE182 !选择单元类型 ET, 2, TARGE169 ET, 3, CONTA171 KEYOPT, 1, 3, 0 !设置单元关键字(1为第一个单元,3为K3,1为所选项(Plane stress=0; Axisymmetric=1; Plane strain=3)) MP, EX, 1, 2.06E5 !输入材
  • ANSYS的接触分析问题如何解决不收敛问题? 1个回答
    如图1和图2是模型图,浅绿色柱状体为铁链,深绿色为水池底部,对铁链和水池底部做接触分析,施加z轴负方向的重力载荷和y轴负方向的水流载荷。只对如图铁链最左端施加约束。铁链只有节点,应该是点面接触。 然而在求解过程中发现Absolute convergence norm会突然增大,如图3所示。图4为错误文件。我在未添加接触对时并没有发现这些问题,所以我相信是在添加了接触对时出现此类问题。请问如何解决?
推荐阅读
ansys结构动力学仿真
ansys结构动力学仿真
技术邻小李 技术邻小李
¥150
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
Isight_Adams Car联合仿真_suspension案例--excle方式
东邪不邪 东邪不邪
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
