顶部banner
Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
chemkin使用问题,qq814327517?
浏览: 2311 回答: 4
 chemkin软件使用
     *               ANSYS Chemkin 17.0 Release 15151                *
     *                      AURORA Application                       *
     *         PERFECTLY STIRRED OR PLUG FLOW REACTOR MODEL          *
     * Copyright(c) 1997-2013 Reaction Design.  All Rights Reserved. *
Running CHEMKIN-PRO
Running Multi-threaded mode
                WORKING SPACE REQUIREMENTS
                 PROVIDED        REQUIRED
 LOGICAL               82             82
 INTEGER             4725           4725
 REAL                5975           5975
 CHARACTER             60             60
This problem requires      0.046MB of memory for the REAL array.
Initializing CHEMKIN Gas-phase Library a component of ANSYS Chemkin 17.0 Release 15151, Build date: Jan 18, 2016
This and All Other CHEMKIN(R) Libraries are Copyright (c) 1997-2013 Reaction Design.  All rights reserved.
LICENSE INFORMATION:
LicNum: 0
           KEYWORD INPUT
          ! problem type definition
          ENRG   ! Solve Gas Energy Equation
          STST   ! Steady State Solver
          ! physical property
          !Surface_Temperature   ! Surface Temperature Same as Gas Temperature
          PRES 1.0   ! Pressure (atm)
          QLOS 0.0   ! Heat Loss (cal/sec)
          TAU 2.0   ! Residence Time (sec)
          TEMP 800.0   ! Temperature (K)
          TINL 1300.0   ! Inlet Temperature (K)
          VOL 1.0   ! Volume (cm3)
          ! species property
          REAC H2O 0.4   ! Reactant Fraction (mole fraction)
          REAC HCL 0.5   ! Reactant Fraction (mole fraction)
          REAC HG 1.85E-6   ! Reactant Fraction (mole fraction)
          REAC N2 3.6   ! Reactant Fraction (mole fraction)
          REAC O2 0.5   ! Reactant Fraction (mole fraction)
          ! solver control
          ATIM 1.0E-9   ! Absolute Tolerance for Pseudo Timestepping
          ATOL 1.0E-9   ! Absolute Tolerance
          DTMN 1.0E-10   ! Minimum Pseudo Time Step (sec)
          DTMX 0.01   ! Maximum Pseudo Time Step (sec)
          IRET 25   ! Number Time Steps Before Increasing
          ISTP 0   ! Number of Initial Pseudo Time Steps
          MAXTIME 100   ! Maximum Number of Pseudo Time Stepping Operations Allowed
          NJAC 20   ! Number of Iterations before Updating Jacobian
          RTIM 0.0001   ! Relative Tolerance for Pseudo Timestepping
          RTOL 0.0001   ! Relative Tolerance
          SFLR -0.0001   ! Minimum Bounds on Species Fractions
          SSMAXITER 100   ! Maximum Number of Iterations per Steady State Search
          TIM1 100.0 1.0E-6   ! Pseudo Time Steps (Fixed Temperature) (none, sec)
          TIM2 100.0 1.0E-6   ! Pseudo Time Steps (Energy Equation) (none, sec)
          TJAC 20   ! Number of Transient Iterations before Updating Jacobian
          TRMAXITER 25   ! Maximum Number of Iterations per Pseudo Time Step
          ! output control and other misc. property
          DFAC 2.0   ! Time Step Decrement Factor
          EPSR 0.01   ! Threshold for Rate of Production
          EPSS 0.001   ! Threshold for Species Sensitivity
          EPST 0.001   ! Threshold for Temperature Sensitivity
          GFAC 1.0   ! Gas Reaction Rate Multiplier
          PRNT 1   ! Print Level Control
          SIZE 10000000   ! Solution Data Block Size (bytes)
          UFAC 2.0   ! Time Step Increment Factor
          ! Number of Continuation 0   ! Continuation Count
          END
  CAUTION...REACTANT MOLE FRACTIONS SUM TO    5.00000185000000
          FOR STREAM INLET1
          MOLE FRACTIONS WILL BE NORMALIZED.
 FIRST SOLUTION ESTIMATE FOR PSR #  1 IS EQUILIBRIUM
     KINETICS MECHANISM:
        Total number of gas phase species     =   21
        Total number of gas phase reactions   =   32
     REACTOR #    1 CONDITIONS FOR INLET NAMED: INLET1
          Residence time in reactor =    2.00     sec
               (which, based on an estimated reactor density =   4.611E-04 gm/cm^3
                       and on a reactor volume  =    1.00     cm^3,
                produces an estimated inlet mass flow rate) =   2.306E-04 gm/sec
          Inlet temperature =   1300.0     Kelvin
          Inlet pressure (assumed equal to reactor pressure) =    1.00     atm
          Inlet density =  2.66763E-04 gm/cm^3
          Inlet mean molecular weight =   28.457     gm/mole
          Inlet molar flow rate      =  8.10240E-06 moles/sec
          Inlet volumetric flow rate =  0.86432     cm^3/sec
               (based on reactor pressure and inlet temperature)
                                     =   11.894     SCCM
                                     =  1.18937E-02 SLPM
     INLET CONDITIONS FOR GAS PHASE MOLECULAR SPECIES IN INLET1
   Species        mole_frac     moles/sec       gm/sec       cm^3/sec        SCCM            SLPM
    HG          3.70000E-007  2.99789E-012  6.01346E-010  3.19799E-007  4.40068E-006  4.40068E-009
    CL           0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    CL2          0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    HGCL         0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    HOCL         0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    H            0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    H2           0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    O            0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    OH           0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    H2O         8.00000E-002  6.48192E-007  1.16774E-005  6.91457E-002  0.95150       9.51497E-004
    CLO          0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    HO2          0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    O2          0.10000       8.10240E-007  2.59267E-005  8.64321E-002   1.1894       1.18937E-003
    H2O2         0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    CLO2         0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    HGO          0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    N2          0.72000       5.83372E-006  1.63422E-004  0.62231        8.5635       8.56348E-003
    HCL         0.10000       8.10240E-007  2.95421E-005  8.64321E-002   1.1894       1.18937E-003
    HGCL2        0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    O3           0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    N2O          0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
 TWOPNT:  DOUBLE PRECISION (TWO POINT BOUNDARY VALUE PROBLEM) SOLVER,
          VERSION 3.30 OF APRIL 1998 BY DR. JOSEPH F. GRCAR.
 TWOPNT:  INITIAL GUESS:
                              PSPRNT: Printing of current solution from TWOPNT:
               RESIDENCE TIME                  2.0000E+00  SEC
               MASS FLOW RATE                  2.3057E-04  GM/SEC
               PRESSURE                        1.000      ATM
               MASS DENSITY                   4.6114E-04  GM/CM^3
               VOLUME                          1.000      CM^3
               TOTAL MASS                     4.6114E-04  G
               TOTAL SURFACE AREA              0.000      CM^2
               TOTAL SURFACE TO VOLUME RATIO   0.000      CM-1
               GAS CHEM HEAT PRODUCTION       -4.4827E-19  CAL/S/CM^3
               TEMPERATURE (FIXED)              800.0000  K
               SURF TEMP, MATERIAL1             800.0000  K  (same as gas temp)
   INLET  GAS PHASE MOLE FRACTIONS
    HG              =  3.7000E-007       CL              =  0.0000E+000       CL2             =  0.0000E+000
    HGCL            =  0.0000E+000       HOCL            =  0.0000E+000       H               =  0.0000E+000
    H2              =  0.0000E+000       O               =  0.0000E+000       OH              =  0.0000E+000
    H2O             =  8.0000E-002       CLO             =  0.0000E+000       HO2             =  0.0000E+000
    O2              =  1.0000E-001       H2O2            =  0.0000E+000       CLO2            =  0.0000E+000
    HGO             =  0.0000E+000       N2              =  7.2000E-001       HCL             =  1.0000E-001
    HGCL2           =  0.0000E+000       O3              =  0.0000E+000       N2O             =  0.0000E+000
   EXIT    GAS PHASE MOLE FRACTIONS
    HG              =  3.9268E-007       CL              =  7.8532E-008       CL2             =  7.1236E-005
    HGCL            =  8.9109E-010       HOCL            =  3.2909E-008       H               =  2.3198E-018
    H2              =  6.4713E-013       O               =  7.9793E-016       OH              =  1.5369E-010
    H2O             =  1.2767E-001       CLO             =  2.3917E-012       HO2             =  8.7422E-014
    O2              =  1.0222E-004       H2O2            =  1.3788E-013       CLO2            =  8.4992E-002
    HGO             =  3.6569E-018       N2              =  7.6592E-001       HCL             =  2.1243E-002
    HGCL2           =  2.5533E-011       O3              =  1.2177E-019       N2O             =  4.3099E-012
   NOx                      (ppmvd): 4.9406E-06
   NOx               (ppmvd 15% O2): 1.4124E-06
 TWOPNT:  SOLVE THE PROBLEM.
                      LOG10   LOG10
              TASK   NORM F  COND J   REMARK
             START    -1.02
            SEARCH    -7.07    0.00   10 SEARCH STEPS
 TWOPNT:  FINAL SOLUTION:
               MASS FLOW RATE                  2.1675E-04  GM/SEC
               PRESSURE                        1.000      ATM
               MASS DENSITY                   4.3349E-04  GM/CM^3
               VOLUME                          1.000      CM^3
               TOTAL MASS                     4.3349E-04  G
               GAS CHEM HEAT PRODUCTION        1.0356E-08  CAL/S/CM^3
    HG              =  3.7000E-007       CL              = -2.5855E-010       CL2             =  1.2625E-010
    HGCL            = -3.1017E-012       HOCL            = -3.7046E-010       H               =  1.2721E-017
    H2              =  1.0529E-022       O               =  3.7773E-010       OH              = -5.8458E-012
    H2O             =  8.0000E-002       CLO             = -1.3646E-018       HO2             =  7.1585E-021
    O2              =  1.0000E-001       H2O2            =  1.0164E-023       CLO2            =  6.2597E-012
    HGO             =  2.7444E-018       N2              =  7.2000E-001       HCL             =  1.0000E-001
    HGCL2           =  2.3362E-013       O3              =  2.2262E-024       N2O             =  3.1742E-022
   NOx                      (ppmvd): 3.4502E-16
   NOx               (ppmvd 15% O2): 2.0435E-16
 TWOPNT:  SUCCESS.  PROBLEM SOLVED.
   PSRTWO: FINISHED FIXED TEMPERATURE, ADDING ENERGY EQUATION
               PRESSURE                        1.000      ATM
               VOLUME                          1.000      CM^3
               TEMPERATURE (INLET)             1300.0000  K
               TEMPERATURE                      800.0000  K
               HEAT LOSS, MATERIAL1            0.000      CAL/SEC
                      LOG10   LOG10
             START     2.42
            SEARCH    -3.11    0.00   13 SEARCH STEPS
               MASS FLOW RATE                  1.3338E-04  GM/SEC
               PRESSURE                        1.000      ATM
               MASS DENSITY                   2.6676E-04  GM/CM^3
               VOLUME                          1.000      CM^3
               TOTAL MASS                     2.6676E-04  G
               GAS CHEM HEAT PRODUCTION       -2.5986E-07  CAL/S/CM^3
               TEMPERATURE                     1299.9997  K
               SURF TEMP, MATERIAL1            1299.9997  K  (same as gas temp)
    HG              =  3.7000E-007       CL              =  4.3647E-008       CL2             = -2.1889E-008
    HGCL            =  1.2433E-013       HOCL            = -1.4348E-010       H               = -1.4140E-013
    H2              = -9.1662E-019       O               =  8.6010E-014       OH              =  4.1713E-010
    H2O             =  8.0000E-002       CLO             = -4.5839E-018       HO2             =  2.5515E-015
    O2              =  1.0000E-001       H2O2            =  1.0240E-023       CLO2            =  7.5114E-019
    HGO             =  3.9924E-018       N2              =  7.2000E-001       HCL             =  1.0000E-001
    HGCL2           =  6.9424E-014       O3              =  5.6680E-019       N2O             =  4.7248E-023
   NOx                      (ppmvd): 5.1357E-17
   NOx               (ppmvd 15% O2): 3.0417E-17
     OUTLET CONDITIONS:
          Specified residence time in reactor =    2.00     sec
               (which, based on a reactor density  =   2.668E-04 gm/cm^3
                 produces an inlet mass flow rate) =   1.334E-04 gm/sec
          Outlet mass flow rate          =   1.334E-04 gm/sec
          Rate of Mass Loss to the walls =    0.00     gm/sec
          Outlet and reactor temperature =   1300.0     Kelvin
          Outlet and reactor pressure    =    1.00     atm
          Outlet and reactor density     =  2.66764E-04 gm/cm^3
          Outlet and reactor mean molecular weight =   28.457     gm/mole
          Outlet molar flow rate         =  4.68715E-06 moles/sec
          Outlet volumetric flow rate    =  0.50000     cm^3/sec
               (based on reactor pressure and temperature)
                                         =   6.8804     SCCM
                                         =  6.88039E-03 SLPM
     OUTLET CONDITIONS FOR GAS PHASE MOLECULAR SPECIES:
   Species        mole_frac     #/cm^3       moles/sec       gm/sec       cm^3/sec        SCCM
    HG           3.70000E-07   2.08877E+12   1.73424E-12   3.47872E-10   1.85000E-07   2.54574E-06
    CL           4.36471E-08   2.46402E+11   2.04580E-13   7.25299E-12   2.18235E-08   3.00309E-07
    CL2         -2.18889E-08  -1.23570E+11  -1.02597E-13  -7.27472E-12  -1.09445E-08  -1.50604E-07
    HGCL         1.24332E-13   7.01894E+05   5.82761E-19   1.37557E-16   6.21659E-14   8.55450E-13
    HOCL        -1.43475E-10  -8.09965E+08  -6.72489E-16  -3.52790E-14  -7.17375E-11  -9.87164E-10
    H           -1.41402E-13  -7.98261E+05  -6.62771E-19  -6.68054E-19  -7.07009E-14  -9.72899E-13
    H2          -9.16621E-19   -5.1746      -4.29634E-24  -8.66116E-24  -4.58310E-19  -6.30670E-18
    O            8.60100E-14   4.85555E+05   4.03142E-19   6.45003E-18   4.30050E-14   5.91782E-13
    OH           4.17134E-10   2.35486E+09   1.95517E-15   3.32522E-14   2.08567E-10   2.87004E-09
    H2O          8.00000E-02   4.51627E+17   3.74972E-07   6.75524E-06   4.00000E-02   0.55043
    CLO         -4.58387E-18   -25.877      -2.14853E-23  -1.10547E-21  -2.29193E-18  -3.15388E-17
    HO2          2.55145E-15    14404.       1.19590E-20   3.94729E-19   1.27573E-15   1.75550E-14
    O2           0.10000       5.64533E+17   4.68715E-07   1.49983E-05   5.00000E-02   0.68804
    H2O2         1.02396E-23   5.78058E-05   4.79944E-29   1.63252E-27   5.11979E-24   7.04522E-23
    CLO2         7.51139E-19    4.2404       3.52070E-24   2.37478E-22   3.75570E-19   5.16813E-18
    HGO          3.99240E-18    22.538       1.87130E-23   4.05303E-21   1.99620E-18   2.74692E-17
    N2           0.72000       4.06464E+18   3.37475E-06   9.45381E-05   0.36000        4.9539
    HCL          0.10000       5.64533E+17   4.68715E-07   1.70898E-05   5.00000E-02   0.68804
    HGCL2        6.94243E-14   3.91923E+05   3.25402E-19   8.83454E-17   3.47122E-14   4.77666E-13
    O3           5.66800E-19    3.1998       2.65667E-24   1.27516E-22   2.83400E-19   3.89980E-18
    N2O          4.72481E-23   2.66731E-04   2.21459E-28   9.74702E-27   2.36241E-23   3.25085E-22
                         DETAILED SPECIES BALANCE
                                   (all rates are in moles per sec)
   SPECIES           INLET_FR    OUTLET_FR  GAS_PROD_RATE  GAS_DEST_RATE   SURF_NET_PROD    TOTAL_NET
 HG                   1.734E-12     1.734E-12     1.940E-14     1.901E-14      0.00         3.878E-16
 CL                    0.00         2.046E-13     5.618E-12     4.922E-14      0.00         5.364E-12
 CL2                   0.00        -1.026E-13     2.450E-14    -2.129E-16      0.00         1.273E-13
 HGCL                  0.00         5.828E-19     5.623E-12     1.505E-13      0.00         5.472E-12
 HOCL                  0.00        -6.725E-16     2.200E-17    -1.274E-16      0.00         8.219E-16
 H                     0.00        -6.628E-19     1.312E-13    -1.508E-14      0.00         1.463E-13
 H2                    0.00        -4.296E-24    -4.283E-24    -1.442E-35      0.00         1.332E-26
 O                     0.00         4.031E-19     1.381E-18     5.931E-16      0.00        -5.922E-16
 OH                    0.00         1.955E-15     5.928E-15     4.103E-15      0.00        -1.299E-16
 H2O                  3.750E-07     3.750E-07     4.080E-15     5.463E-15      0.00        -2.524E-13
 CLO                   0.00        -2.149E-23     6.751E-21    -8.213E-24      0.00         6.781E-21
 HO2                   0.00         1.196E-20     1.196E-20     4.823E-29      0.00        -6.859E-26
 O2                   4.687E-07     4.687E-07     1.045E-27     1.196E-20      0.00        -3.153E-13
 H2O2                  0.00         4.799E-29     4.799E-29     2.362E-40      0.00         5.445E-34
 CLO2                  0.00         3.521E-24    -1.635E-33     1.098E-36      0.00        -3.521E-24
 HGO                   0.00         1.871E-23    -8.212E-24     6.754E-21      0.00        -6.781E-21
 N2                   3.375E-06     3.375E-06     6.880E-39     2.273E-28      0.00        -2.270E-12
 HCL                  4.687E-07     4.687E-07    -9.617E-15     1.359E-13      0.00        -4.621E-13
 HGCL2                 0.00         3.254E-19     1.311E-13     5.604E-12      0.00        -5.472E-12
 O3                    0.00         2.657E-24     2.727E-24     1.045E-27      0.00         6.900E-26
 N2O                   0.00         2.215E-28     2.273E-28     6.880E-39      0.00         5.866E-30
                         DETAILED ELEMENT BALANCES
 ELEMENT          INLET_FR      OUTLET_FR    TOTAL_NET
 C                   0.00          0.00          0.00
 O                  1.312E-06     1.312E-06    -8.829E-13
 CL                 4.687E-07     4.687E-07    -3.153E-13
 HG                 1.734E-12     1.734E-12    -1.167E-18
 H                  1.219E-06     1.219E-06    -8.198E-13
 N                  6.749E-06     6.749E-06    -4.541E-12
 Total CPUtime: 1 second or less
文件压缩包链接:http://pan.baidu.com/s/1mh8dHhe 密码:04ki     想做出别人论文第16页效果
ANSYS 能源化工 工程热物理及仿真 流体力学及仿真
全部回答 (2)
结构力学 2017年2月17日
问题描述清楚点啊,而且如果想单独沟通,最好去发布一个协作任务
2017年2月17日
评论 2 点赞
技术工 2017年2月16日
@液风@龙樱@Big_Ocean@steve_zheng
2017年2月16日
相似问题
查看全部
  • s-ale模拟爆炸计算无法进行? 1个回答
    模拟辛春亮老师第二版书中7.1例子,用sale方法模拟炸药炸钢板,用ls-run计算。几个小时进度一直在0%。 这是lsrun.out文件 License option : check ansys licenses only *************************************************************** * ANSYS 2022 R2 LEGAL N
  • ls-dyna 求解出错要怎么解决? 2个回答
    Executing with ANSYS license Input file: g:\xiansh~1\01\01_files\dp0\sys\mech\lsdyna~1.k The native file format : 32-bit small endian Memory size from default : 20000000 on UNIX computers note the fol
  • SPH in bucket sort of particles time? 1个回答
    在做伪二维sph爆炸模拟时,求解出现警告后就卡住了,不知道哪里出现了什么问题,求大佬指点! Beginning of keyword reader 11/06/23 23:20:58 Memory required to process keyword : 1172409 Additional dynamic memory required : 4913553 input of data is c
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
Isight_Adams Car联合仿真_suspension案例--excle方式
东邪不邪 东邪不邪
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
