Logo 折叠
学习从这里开始
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
关于ls-dyna警告Warning 20006 (STR+6)和 Warning 30069? 100
浏览: 3004 回答: 1
在计算的时候出现这样的警告要怎么修改呢?各位大神们
*** Warning 20006 (STR+6)
     reset D3PLOT output interval from 0. to 6.0000E-02
 expanding   memory to        4305 d         614 material, node and element data
 expanding   memory to        4399 d         624 mat add general damage 0
 expanding   memory to        4459 d         624 material added airbag porosity leakage
 expanding   memory to        4477 d         624 material properties
 expanding   memory to     9776896 d     1203593 element data for composite material
 expanding   memory to     9777030 d   115385350 gradient of damage data
 expanding   memory to    22214809 d   115385367 user control for contact interfaces
 contracting memory to    22214795 d   115385367 thermal expansion 0
 expanding   memory to    23416719 d   115385403 temp index array for node sorting
 contracting memory to    22214795 d   116587331 just because?
 expanding   memory to    23103195 d   118991197 arbitrary element numbering input
 contracting memory to    22214795 d   153641801 thick shell int. pt. strain
 expanding   memory to   541372113 d   154902571 process element material data
 expanding   memory to   541374119 d   154902565 load curve data
 expanding   memory to   541377519 d   154902565 time history data
 contracting memory to   541376135 d   154902589 user_define_loading_set
 expanding   memory to   541378735 d   154902589 regularize time history data
 contracting memory to   541376139 d   154902589 *DEFINE_ELEMENT_DEATH
 contracting memory to   541376139 d   154902589 rigidwall definitions
 expanding   memory to   542617289 d   154902589 nodal constraint sets
 expanding   memory to   547601722 d   154904044 contact interfaces
 expanding   memory to   550006570 d   154904044 implicit contact 1
 *** Warning 30069 (INI+69)
     node 379036 of contact interface 1 moved -7.7969E+00
     node 379037 of contact interface 1 moved -1.2755E+01
     node 379038 of contact interface 1 moved -1.4877E+01
     node 379039 of contact interface 1 moved -1.4169E+01
     node 379040 of contact interface 1 moved -1.0627E+01
     node 379041 of contact interface 1 moved -4.2524E+00
     node 379042 of contact interface 1 moved -4.2468E+00
LS-DYNA
全部回答 (1)
Wonderful仿真 2022年2月6日
20006一般不需要修改,计算机会自动增加内存,或者可以自己通过memory关键字增加内存,30069代表模型有干涉,可以检查调整,若是做干涉分析那倒不用管它
2022年2月6日
相似问题
查看全部
  • dyna在计算sph模拟的流固耦合问题时,总是中止计算,是什么原因? 1个回答
    Input file: G:\sph\1.k The native file format : 32-bit small endian Memory size from command line: 100000000 Binary file : 32 bit IEEE selected expanding memory to 100000000 starting ls-dyna ********
  • 1个回答
    *************************************************************** * ANSYS 2021 R1 LEGAL NOTICES * *************************************************************** * * * Copyright 1971-2021 ANSYS, Inc. Al
  • LS-DYNA做爆破数值模拟,运行k文件后1分钟左右无故终止? 4个回答
    Date: 08/20/2023 Time: 21:43:43 ___________________________________________________ | | | Livermore Software Technology, LLC | | | | 7374 Las Positas Road | | Livermore, CA 94551 | | Tel: (925) 449-25
推荐阅读
ansys结构动力学仿真
ansys结构动力学仿真
技术邻小李 技术邻小李
¥150
UG NX塑胶模具设计教学
UG NX塑胶模具设计教学
UG/CAD模具设计教学 UG/CAD模具设计教学
免费
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵 咸鱼氮泵
免费
Fluent中升力和阻力的计算
Fluent中升力和阻力的计算
宁博士CAE团队 宁博士CAE团队
免费
后保险杠低速碰撞分析
后保险杠低速碰撞分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥70
基于iSIGHT+Workbench的开孔平板性能优化
sjktzy sjktzy
¥5
Hyperworks CFD v2022.1前后处理教程
ALTAIR ALTAIR
免费
线控底盘市场趋势分析
线控底盘市场趋势分析
小木匠砍树 小木匠砍树
免费
张量计算课程合集
张量计算课程合集
引垂思汀 引垂思汀
¥50
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国 VI-grade中国
免费
Isight_Adams Car联合仿真_suspension案例--excle方式
东邪不邪 东邪不邪
免费
ANSYS APDL 单元生死在3D打印中的应用
some some
¥50
4-平版印刷墨斗仿真手把手解说视频教程CAD-GAMBIT-fluent6.3-FLUENT15.0
仿真助手 仿真助手
¥39
Adams Car 转向系统的搭建与介绍
仿真分析 仿真分析
¥19.8
2018 OptiStruct用户大会周明博士“仿真驱动设计”演讲
ALTAIR ALTAIR
免费
AutoCAD小白入手教程(二)
AutoCAD小白入手教程(二)
wenyun wenyun
免费
新一代极速仿真建模平台 ——MSC APEX软件培训
Cruise Cruise
免费
优化软件modeFRONTIER优化气道流程介绍
IDAJ中国 IDAJ中国
免费
七步台阶法暗挖隧道施工
七步台阶法暗挖隧道施工
一直那么好
¥8.8
测量不确定度的应用实践
测量不确定度的应用实践
HBK测试与测量 HBK测试与测量
免费
