The maximum contact stiffness is too big?
仿真过程中出现The maximum contact stiffness is too big. This may affect the accuracy of the results. You may need to scale the force unit in the model. 我的结构是一个铜薄片上面是一层柔性层
全部回答 (1)
是error还是warning,金属和柔性体做接触,接触参数要好好设置,否则负体积
